P1000m5 2017 1000-5 PIONEER LE by UTVMI
utvmi
utvmi
265
574
Got the wetsounds all hooked up its loud not a lot of bass maybe sub woofer later on.
All the Leds are wired up and working.
Switch Panel is all done still have room for another switch and the one labeled Dome I'm not using its the 3rd circuit that runs to back pry be used for some lighted whips.
I have both the Voltage gauges wired to a relay that is on back of switch panel and its set up as ground relay so once power comes on it completes the circuit and reads voltage of each battery.
I have everything running of the second batter, witched are tagged into one of the PDM60 circuits so when that turns on it light switches,
The power button also draws its power from spare battery.
Pdm60 runs everything expect the wetsounds, and main power in to the pdm that comes of Blue Sea fuse panel.
Pdm60 has a 7 seconds Start up delay and 5 seconds off delay, If I remember right, I programed the PDM 60 with Laptop and USB cable.
Have a blue sea 200a fuse on second battery.
20170702 142610
20170702 232115
20170702 221109
20170702 221839
20170702 232133
20170702 232500
20170702 232506
20170703 175829
Reactions: Dp5hunter
E
elkguide
3,377
7,964
Vermont
VERY nice.
Reactions: utvmi
Deleted member 3748
So I got my replacement wireless winch controller installed, the first one would just click and the winch wouldn't move.
The controller ends up being really easy to install when you have one that works..:D
Amazon.com: 12V 12 Volt Wireless Remote Control Kit for Truck Jeep ATV Winch: Automotive
I just tested all of the wires to see which one does what... Fairly simple. Do you think this controller is waterproof? It doesn't really say at Amazon. I have a waterproof box it will fit in and I may use that.
Reactions: Dp5hunter and utvmi
utvmi
utvmi
265
574
I put the wireless controller in the glove box, I might even put it in a zip-lock bag just to be safe.I think you get it wet Might be bad thing,..:D
