P1000m5 2017 1000-5 PIONEER LE by UTVMI
utvmi
utvmi
265
574
I just picked this up today for the wife's Birthday, actually she got it a few days early.
Ordered it with the Warn 4500 # Winch
Hard Roof
Rubber Bed mate
Honda Tilt out wind shield
Plan to add second battery and Light Bar, Radio, switches. etc.
Have tailgate cables on the way.
Also ordered one of the Honda 1000 V2 Rack that Brick City Fab sells.
The warning plate is different then the 2016 and there's not a lot of room under the hood.
Not sure how fast or slow this build is going to go..:)
20170602 174122
20170602 174543
20170602 222922
20170602 223007
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Hard Roof
Rubber Bed mate
View attachment 45425 View attachment 45426 View attachment 45427 View attachment 45428
Welcome aboard! Sharp rig. The warning plate is smaller but I think you can still cram several switches in there. If ya got any questions don't be afraid to post up. Someone here I'm sure has the answer.
39,079
Welcome from Alabama! Glad you're here on Hondasxs
CP: This group looked for anything rough and had a great time. It wasn't all about who was the best or correct line just some good ol boys with a beer and a 4wd.
utvmi
utvmi
265
574
Thanks for all the warm welcomes !!
So today I just got a couple simple things done, I put on the winch stop and after trying to figure out where to put my Michigan Orv and Orv Trail stickers where they would stick and not fall off I decided to just make a simple plate and pop rivet it on, figured it wont fall off and the Stickers actually stick to the metal versus the plastic.
The DNR can't say its not visible and I just didn't want them stuck on the roll cage...:p
20170603 131917
20170603 135105
20170603 180505
20170603 180859
105,354
View attachment 45520 View attachment 45521 View attachment 45522 View attachment 45523
Welcome from Michigan! Make sure you check your other thread you posted for some info! Nice rig! We all have lots of advice for you if you need it just ask!
Also on your ORV stickers, I've put them on the exhaust cover like that before and they eventually started to melt. Hopefully the metal plate you put on there will buffer some of that heat but it still gets pretty warm. I cleaned the plastic on the tailgate below the HONDA with some rubbing alcohol and put them on there. So far so good! Even the power washer hasn't budged them. Just my 2cents.
utvmi
utvmi
265
574
Thanks for the info I was thinking about the rear tailgate also but the, V2 rack would block my stickers so I went the other route hopefully with the metal it doesn't get to hot.
Here is a pic of the rack I have coming. He is going to see if the second RotoPax will fit between the cooler and spare, Also the spare tire mount will hold up to 30 inch tire.
18765943 10155059537830783 7173269162020347287 n
105,354
That's the rack I've Ben thinking about. Just other priorities for now! Lol. It will be awesome if that plate does well with the heat. If so I'll do the same thing.
Reactions: sharp and utvmi
105,354
You know, my wife just mentioned something about the rack, that you can't see the break lights when it's installed. If your familiar with riding on michigan trails, this is very important that people see your lights. Unless there's something I'm not seeing in the pics?
Similar threads
