P700 2017 P700-2 Antifreeze leaks around head gaskets.
Thedirkster
Thedirkster
15
16
Ceres, Pa
I JUST purchased a 2017 P700-2 2 weeks back. Since then it has been sitting in garage as haven't had time to ride. When purchased it had 5 miles on it, now it has 7. Basically to and from mail box. Upon return from mail box this morning I decided to check the oil and look around to more familiarize myself with the machine as I was thinking on adding accessories.
What I found was what appears to be antifreeze leaking out of all the head gaskets (see pictures). Are you kidding me? Is this normal? I keep trying dealer but nothing from Salesman as of yet. I have a feel I'm going to get stuck with a problem prone lemon. Out of ALL of my Hondas this is the first time I've ever had an issue.
Anyone have any suggestions or thoughts ???
The Dirkster...
Antifreeze1 Antifreeze2
swsebek
swsebek
2,854
5,828
pa
I'm not sure about that. Give it a good lick and see if it's sweet. Looks more like somekind of cleaner or something else they didn't clean off. That was antifreeze you would taste it in the air when warmed up.
Mudwing
Mudwing
36,959
306,563
The Mud holes
It looks like it's dried up. I'd try to get dealer to look at it, in order to document it. I'd also check my coolant level so I don't cause more damage. I'd also keep driving to shake loose any problems, it's still under warranty. And last thing, how far is your mailbox from your house?!
Thedirkster
Thedirkster
15
16
Ceres, Pa
1) Coolant level is within range in reservoir.
2) Mailbox is 600 feet from garage.
3) Pictures don't do it must justice, but all places where gaskets are have the blueish "stuff".
41,798
The seam below the lower plug and the coolant temp sensor is the head gasket. It's leaking from above that. That's good.
If I had to guess, either the o ring in the t-stat or where the hose attaches to the t- stat housing. Could also be that someone left the bleeder screw not quite tight as well. Simple fixes that your dealer will have no problem with when you make them fix it.
63,560
There is residue on the thermostat housing. If its dry, I would document and clean it up.
Could be as simple as them not cleaning up when after a coolant air bleed.
Thedirkster
Thedirkster
15
16
Ceres, Pa
PROBLEM RESOLVED - I took the buggy into the dealer. They discovered the leak was indeed coming from the T-stat housing. Apparently the t-stat has an oval offset about it, and if it isn't seated "just so" - to spec it causes a leak. Dealership called around nationally and this problem has been 'registered' before. The anomaly comes when tightening things down to the oval shaped T-stat can turn and end up not seating itself correctly - causing the leak. Please DO NOT quote me hear but I do believe this issue is unique to the 2017's from what I gathered from the dealership......Which by the way was awesome.
I'd like to thank EVERYONE for their input in helping me resolve this issue....Now back at looking for accessories to add on......:)
The Dirkster...
41,798
The Dirkster...
I was going to mention in my 1st post that someone on FB a few days ago had mentioned a tstat housing leak. I believe it was also a 2017.
Glad they got it fixed for you.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Thanks for the info... I have not noticed anything on mine, but I will keep a sharp eye out...
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Mine developed this issue .. Mine is a 2017.
T-stat housing... I went ahead and put in a new o-ring gasket as well.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Did it myself....could have taken in under warranty...but it is really not that big of a deal to fix yourself. If it had still leaked, I would have taken it in..
Reactions: swsebek and Mudwing
Mudwing
Mudwing
36,959
306,563
The Mud holes
I’d hate to say but mine has a leak too. Did you need to purchase coolant, also? I think I’m going to take care of it myself after it warms up a bit.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Don't sweat it...once you take off enough stuff to be able to get in there and see it..and get to it...better -- It will make sense how to fix it. You have to line up the the "bleed hole" with the "lug" or raised nipple on the housing. You will see the lug on the side of the housing. I don't think I used much anti-freeze. Just take the radiator cap off before you start so there is not pressure on the system. You can always bleed the system using the bolt on top of the housing once you have it all back together if you think there may be air in there.
9 ft pounds is all you need to tighten the t-stat housing bolts (2) up to.. Don't get too heavy with them. check the rubber o-ring when you are in there and make sure it looks good. If your not sure if it is good...replace...it's only a couple dollars for a new one.
41,798
So the t-stat housing isn't clocked right and thats causing it? Not a pinched O-ring?
Seems like about 1 a week pops up on FB with this...
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I think that is it..the alignment is not correct. The O ring looked OK, but I replaced it anyway. You have line up the bleed hole with the lug on the housing...and...make sure the o ring is seated correctly.
Mudwing
Mudwing
36,959
306,563
The Mud holes
Thanks! I’m gonna grab the o ring and coolant soon. I’ll update soon!
Reactions: Deluxe700
