2019 1000-5 clutch slipping
Cedric239
Naples fl
Hi guys I have 2019 1000-5 that I believe has a burned clutch just have not experienced this before. So when I start it and let it warm up on idle I can put it in reverse and have to give it a little throttle before you feel it catch and same thing when put in L for 1st gear no to strange. From 1st to seccond it shifts normally but 2nd to 3rd the rpm will rev way up and you have to let off the pedal for it to shift into 3rd. 3rd to 4th it’s perfect but same high rev going into 5th. Drained the oil didn’t see anything abnormal. Also tried a clutch re learn about 15 times and it refuses to take complete it. Wondering if anyone has had this issue
Pilotadam
Pilotadam
326
735
Pell City, Alabama
I had the same problem. You burned up half the clutches. You will need to replace the one side of the clutch pack.
Sent from my SM-G781V using Tapatalk
