So, the Rhino axles do work on a 23 model. They just require some persuasion from a rubber mallet. They were so tight when I tried to install them before, I was afraid to break something. What I did that worked was removing the hub from the knuckle, installing the axles, then installing the hub onto the axle and simultaneously into the knuckle with a rubber mallet. Sorry for the confusion, the Limeted Edition axles do work on a 23 Trail.
