P1000 23' Trail Front Axle
Rocksteady2246
Rocksteady2246
11
31
  1. Looking to buy
I'm looking for recommendations for an aftermarket axle for a 23' Trail 1000-5. I had ordered SUPERATV Rhino axles for the LE with i4wd. The axles fit in the front differential but the splines are too large to fit in the hubs. I can't find anything. I have a TTC 3" lift. Thanks.
20230708 085312
Probably not going to find anything for awhile since they changed the spline size in 2022.
Rocksteady2246
Rocksteady2246
11
31
  1. Looking to buy
What he👆 said......too new for any aftermarket axles I think.
🤔...looks like you could use some ball joints too...
Balljoints are good, off if a 3/4 ton truck I believe. I'm debating buying hubs off of an older model and seeing if they fit on my 23'. Rhino axles should fit if that's the case
106,049
You need to send a PM to @SuperATV with your issue. Hes real good at getting to the bottom of your situation with there products.
Having a lift with arched arms is also an issue in your situation.
U can use stock length axels but u stand the possibility of busting them. I personally am not a fan of bracket lifts. Had one, changes your suspension geometry and other things giving u more ware and tear on certain parts
Rocksteady2246
Rocksteady2246
11
31
  1. Looking to buy
Welp...good to know. We'll have to cut the fitment for the 2023+ LE front axles. I think OE is going to be the only option for now.
I emailed SUPERATV and my return was accepted. I did order hubs from a 2018 on ebay. I am going to see if I can use the hubs on a 2023 and if so, if I can use the Rhino axles.
Rocksteady2246
Rocksteady2246
11
31
  1. Looking to buy
So, the Rhino axles do work on a 23 model. They just require some persuasion from a rubber mallet. They were so tight when I tried to install them before, I was afraid to break something. What I did that worked was removing the hub from the knuckle, installing the axles, then installing the hub onto the axle and simultaneously into the knuckle with a rubber mallet. Sorry for the confusion, the Limeted Edition axles do work on a 23 Trail.
20230722 182307
Did you use the nut from an older model?
Honda increased the thread size in 2022.
Reactions: Scoop and Smitty335
