P1000 2nd battery and amp wiring
P
PalmettoFarmer
19
66
Providence, SC
I'm in the process of installing a second battery and a sound system currently. Im using the isolator from the store. Its been a while since I've wired up an amplifier, but i have a question. I used to always hook the amp ground within a few feet of the amp, which is what i was planning on doing on the pioneer.
As I was reading a few posts about 2nd battery wiring somebody asked if they could hook winch positive to auxiliary and negative to main. It was suggested to hook both to auxiliary because the winch would pull from both. This got me to thinking, if I ground amp to ROPS and positive to aux like i was planning, would it pull power from both batteries? My thinking is if i leave radio playing for a while and battery goes dead, no big deal, its just the aux and it will still crank. But I dont want it to kill both batteries in the middle of nowhere.
Yall suggest running amp ground all the way down to aux bat?
300 watt rms amp
Rayger143
Rayger143
2,745
23,764
Winfield, BC Canada
300 watt rms amp
The grounds or negative side are all tied together and only the positive is isolated so the battery that you have your positive connected to will be supplying the power because of the isolator. You are doing it right in my opinion.
bumperm
bumperm
1,851
6,656
Gardnerville, NV
Correct, common ground is the frame so it doesn't matter which point you connect anything to ground, so long as it's a good ground. If the two battery positives are isolated one from the other, drawing current from either will not put a load on the other one. Only when you connect the positives will they behave as a single battery bank.
Reactions: Rayger143
