2WD and 4wd
Yannick
Yannick
6
6
Canada Québec City
Hello group !!! just have a new 2016 Pioneer 1000-5 for a couple of week, and i just love it !!! but today, i got a strange problems... i can not switch to 4WD, i mean the shifter go to the 4WD position but it's not engage it. It stock to 2WD, turf mode is ok. All cable look good.... Any ideas ? thx. pioneer is only 458km.
Reactions: ChadD
Yannick
Yannick
6
6
Canada Québec City
2WD and Turf mode working fine... it's the 4WD and diff lock that doesn't work, and no light in the dash board... Any tips ?
Reactions: ChadD
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,158
Cullman, AL
  2. Other Brand
Most likely the adjustment under the bed needs tweaking. The cables will stretch a little over time and wear and tear. It can be finicky to get right. You need to move it 40' or so after adjusting to check.
Reactions: ChadD
Yannick
Yannick
6
6
Canada Québec City
Enen if the turf mode is already working ? because the 4wd cable go to the front diff.
Reactions: ChadD
Mike129
Mike129
125
240
Iowa
Snuffnwhisky is probably right on the cables in the box under the bed needing adjustment. Had similar issue with mine and had the dealer adjust at first service. Haven't had a problem since.
Reactions: ChadD and Yannick
Delton
Delton
Honda Fanboy
9,967
31,487
Middle TN
He is correct about it being "finicky" too. I repeatedly adjusted mine according to the service manual and it wouldn't work right. I kept playing with it til it worked perfectly (didn't even pay attention to the index marks on the box).
TractorMan
TractorMan
98
159
Same here. I did not pay attention to the index marks on the box either. Works as it should now.
Reactions: ChadD
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,158
Cullman, AL
  2. Other Brand
P1000 - 4wd display
The last post has the download of the manual pages. Inside the box is 2 alignment marks as shown in the manual above.
Reactions: ChadD
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,158
Cullman, AL
  2. Other Brand
At the takeover mine started popping in the front end. Thought I broke the front diff. Just needed 1 round tighter on both cables going to the front in the box in the left rear floorboard.
Reactions: ChadD
Bjpurgason
I have a 2015 pioneer 500 my 4wd 2wd shift knob feels loose or like the cable has come off how do I fix and is it fairly simple
Reactions: ChadD
lee
lee
Village Idiot
2,375
13,423
Springfield Ohio
@JACKAL this guy wants the p5 section.
More likely to find someone to answer there.
Reactions: ChadD
Bjpurgason
Sorry new to this sight haven't gotten it figured out
Reactions: Mudder
Mudder
Mudder
NTC Ambassador of Walls
11,605
87,353
inspect under hood for the lever connection. The other cable end is on the passenger side of the front differential under a black plastic cover. Check under that cover, there should be a threaded end, spring and nut. This is where the 4wd is engaged. You can also check the 4wd sensor for the dash indicator on the drivers side of the diff, make sure the wire is connected, as it can be pulled off.
See 11:20 in video for cover.
