I'd skip it, it messes with the camber geometry, I would try shocks and taller tiresHas anyone used the super atv 3” bracket lift and has anyone done it on a le model? Or has installed it with fox shocks? How dose that work?
Very confused on how this works or if it’s even worth it
Ok sounds like bracket lift is not good I already have arms and 6 in portals I guess I could try to run preload down some more I have 1” in front already but once I load it down with people my 33s rub on a sharp turn I do have the stops in the rack so other than going with ttc arms that have built in lift and bigger tires or 8 in portals which would be way to much money for 2” I have pretty much reached my max hight not a big problem I conquered just about everything the park had to offer last weekend so I was very happy with my buggyI'd skip it, it messes with the camber geometry, I would try shocks and taller tires
Holy cow! Thats pretty tall!Ok sounds like bracket lift is not good I already have arms and 6 in portals I guess I could try to run preload down some more I have 1” in front already
on a side note has anyone tried the ttc arms?
U want to do this but I’m not sure how to find the ones I need or how to change them I read the form somebody posted on it but was still left confusedAnother recommendation, do you still have stock coils on the fox shocks? You may have a better ride quality and gain some lift with added pre load if you swap out to single rate coils.
“I want”U want to do this but I’m not sure how to find the ones I need or how to change them I read the form somebody posted on it but was still left confused
I have super atv arms and what is ?c-fab is that custom fabricated?Here are a couple that have them.
@P1K5Dave
P1000 - P1K5Dave's TTC 3" Lift and Fox Shock Install
Edit 6/25/21 - I was originally going with the C-fab arms. I changed direction to the Texas Tough Customs kit. Edit 7/24/21 - Removed 814 Trail Series and replaced with Fox QS3s. just decided to blow a wad of money to upgrade my suspension. The parts are on order, and both companies are...hondasxs.com
@DennyChapman
P1000 - Bubba’s Build
Went with the 6” TTC lift in illusion orange , 33x9x20 OutBack’s with 20” mavericks. 2 flood lights in the back, a 24” bar light in front , 8 rgb rock lights , 4’ whip lights , Rockford rgb 8”tower speakers, 2 twelve P2’s , 1500 watt 5 channel element ready Rockford amp, Rockford head unit...hondasxs.com
I see others on here as well but I don't see alot of forum activity from them.
What brand arms do you currently run? C-fab adds lift with less cost than TTC.
Your good with the SATV arms. Just upgrade the springs. Your already having issue with weight. You'll b happy you didI have super atv arms and what is ?c-fab is that custom fabricated?
SATV said they don’t fit the LEs… I think he has an LEYour good with the SATV arms. Just upgrade the springs. Your already having issue with weight. You'll b happy you did
C-fab is another manufature
Well slap my ass and call me Shirley! 🤣SATV said they don’t fit the LEs… I think he has an LE
They might be on crack?I’m very confused on what your talking about I have a limited edition and I do have the satv arms on them
View attachment 358270 View attachment 358271 View attachment 358272
