P1000 3” satv bracket lift?
  • Thread starter Bigmanlittlebuggy
  • Start date
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Has anyone used the super atv 3” bracket lift and has anyone done it on a le model? Or has installed it with fox shocks? How dose that work?
Very confused on how this works or if it’s even worth it
8A817909 0449 4E91 89D9 3B1F6513893F
207,989
I'd skip it, it messes with the camber geometry, I would try shocks and taller tires
107,095
Exactly what @Smitty335 said. Your half way to a natural more versatile and adjustable lift. Just need the aftermarket arms of your choice, i prefer the SATV ones. Then add some pre load to those Foxies and your cooking with Kerosene
Seadonist
Seadonist
380
1,117
New Orleans
Installed it on mine (not LE model thought) and took it off. It makes the ride horrible. Violent. The Fox shocks provide some preload that was enough for me to run 28” Mudda Inlaws without the bracket lift
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Ok sounds like bracket lift is not good I already have arms and 6 in portals I guess I could try to run preload down some more I have 1” in front already but once I load it down with people my 33s rub on a sharp turn I do have the stops in the rack so other than going with ttc arms that have built in lift and bigger tires or 8 in portals which would be way to much money for 2” I have pretty much reached my max hight not a big problem I conquered just about everything the park had to offer last weekend so I was very happy with my buggy
on a side note has anyone tried the ttc arms?
107,095
Holy cow! Thats pretty tall!
update your springs on the foxes. Youll get more out of the pre load and can handle your weight. Theres a few threds on here with options. Search it!
Robobrainiac
Robobrainiac
2,460
8,566
Here are a couple that have them.
@P1K5Dave
@DennyChapman
I see others on here as well but I don't see alot of forum activity from them.
What brand arms do you currently run? C-fab adds lift with less cost than TTC.
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Another recommendation, do you still have stock coils on the fox shocks? You may have a better ride quality and gain some lift with added pre load if you swap out to single rate coils.
U want to do this but I’m not sure how to find the ones I need or how to change them I read the form somebody posted on it but was still left confused
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
@P1K5Dave
@DennyChapman
I have super atv arms and what is ?c-fab is that custom fabricated?
P1K5Dave
P1K5Dave
2,180
8,158
Petoskey, MI
Did you read this thread?
