P1000 3 Bars Again!
Redmoon
Redmoon
265
456
Prescott Az.
Last summer I purchased a used 2016 1000-5 and had the same issues. Boiling over constantly and fan not working. After looking at it the fan was junk and I replaced that. Then took it out on a long ride a few weeks later and hit a couple times 3 bars, granted I was up like 10k elevation. I then burped the system used a professional air evacuation system for cooling systems and thought that would work. Took my machine on another ride and nope it still boils over. Last resort was try another radiator cap and wouldn’t you know it that was a fix. Have had no boiling in over 8 months and have ridden it pretty hard.
I have read that changing the cap solved the problem for some. I’m going to order one. Not even going to test the old one.
Herbie
Herbie
86
190
Richmond, TX
Did you happen to test the old or new cap in hot water, to see what temperature it opened? I bought a new cap, but didnt install it last summer because I tested my old one and it opened at the right temperature (cant remember what it was right now).
Redmoon
Redmoon
265
456
Prescott Az.
No I did not. The cap is a 1.1 (I know that's not the temp) They make a 1.6 which raises the temp 25 deg. any thoughts or knowledge on this cap.
Reactions: Isaiah
Jamesa
Jamesa
I’m not sure what cap i put on, just ordered one through my local Honda dealer. I did play with the old one a bit and it felt like it had a little sand stuck in it. Just the way I could squeeze it, there was no resistance at all so I was like I’ll give a new one a shot.
Reactions: Isaiah
G
GWH
748
2,475
Las Vegas Nevads
History: 2019 P5 LE
Never! Mudded. Never in water deeper than 6" while crossing creek
Radiator is clean and debris free
Fan Always seems to come on
Boiled over last September Riding slowly while scoping Elk
Dealer drained coolant and pumped in all new. Burped system
1200 miles on machine. riding a few days ago going slowly 4-6 mph for an extended period of time approx. 40 min. up rocky trail.
Running Bilge fan all during this climb to reduce heat in engine compartment
Hit 3 bars on the temp gauge WTF! No boil over. Maybe because as soon as I saw 3 bars I shut it down
Riding at this speed is 20% +/- of the time
Question: is this normal under these riding conditions?
My confidence is pretty low in this machines reliability right now. I don't want a machine that requires me to ride above 15 mph so it stays cool enough to not boil over or over heat
Any suggestions that have a proven history to fix this problem would be appreciated
Do you hear the fan running continuously when it’s at three bars?
Reactions: Isaiah
43,434
The cap doesn't open with temp, it opens with pressure. You guys are thinking of the thermostat. The "1.1" is the pressure in bars (roughly 15.9 psi).
G
GWH
748
2,475
Las Vegas Nevads
Dealer here says it was done according to their computer. They will get another chance on Monday.
This will get figured out or it will get sold. Either way I won’t ride a machine that I can’t trust.
On the other hand if you guys tell me that the Pioneer is a machine that cannot be lugged around then I will give some thought to modifying my riding style.
thanks
I lug mine all the time in 100 degree weather, mines a 2016 deluxe 5.Never have any problems.however never have the bars showing I hear the fan cycling. But not staying on constantly, if I hear it running I don’t shut it off till I hear the fan shut off.
radiator caps work on psi,are u guys talking about the thermostat? When it comes to passenger cars and overheating, the thermostat is the first thing to look at , yet nobody brings it up on these threads about the pioneer overheating.I assume they have a thermostat.
Reactions: Mudwing and Isaiah
Redmoon
Redmoon
265
456
Prescott Az.
At three bars it was a hot smell that I noticed first. Then I looked at the temp gauge and saw three bars. First thing I check is the fan running? Yes it was. Next I switched on the bilge fan to move the heat off of the engine. Within 5 minutes it was back to 2 bars and never got above that again. Thing is with one boil over ( I know others have had more) and now this it’s hard to just enjoy the ride when you are constantly monitoring the temp gauge. Oh also it at times smells hot, kinda like the hot of a new machine burning in. I took it all apart after this last ride and found nothing unusual except the muffler looks like it’s gone through some serious heat treatment. This is where the odor seems to come from. I am going to pull the arrester out of it and see if it can tell me anything. Otherwise I have the extended warranty getting the necessary service work done and I might just say F it burn up
Redmoon
Redmoon
265
456
Prescott Az.
Sorry for the rant.
hittoriginal
hittoriginal
South Ogden, Utah
Honda was having some problems with the machine overheating when the fan wasn't coming on correctly. There is a computer reflash performed by the dealer that seemed to fix the problem, or at least fixed my issue. I believe it was for the 2017 and 2019 but don't quote me on that. According to other members of the forum, it also seemed to improve the shifting of the machine.
Here's a link to a different thread talking about it.
So would the 2020s came with the flash already done?
Reactions: Isaiah
O
oldgasser
53
77
Arizona
I saw your post and thought I would share some things I have done and am going to do. My ride is a 2017 1000-5LE which will be 3 years old next month. The 2nd time I had it out it overheated and I immediately shut it down to cool and after getting it back to Quail camp (I also live in NE AZ) I started trouble shooting it. I realized early on that the fan switch was not reliable even after having it replaced under warranty. I also realized I needed a better gauge than the 4 bar set up. After shopping around I chose a Trail Tech digital temp gauge. It is compact, surface mounts on the dash in a very small space and has a built in battery guaranteed for at least 5 years. I had to build an in line hose device for the sender. I put it in the by pass hose which is a 12mm ID hose and no one makes a drop in mount for that size hose. I bought a brass fitting with 1/2" Female pipe threads straight through and a 1/8" Female pipe thread in the center. The tricky part was the adapter for the sensor because, in their infinite wisdom, Trail Tech uses a sensor with 1/8" Male British Pipe Thread. British pipe thread is not tapered like NPT is so the 2 are not compatible. I eventually found an adapter on Amazon that is 1/8" NPT Male X 1/8" BPT Female. I now know to the degree what the coolant temp is. I also installed a SPST toggle switch wired across the radiator fan wires so that I can turn the fan on any time I desire and I have a bilge fan mounted in the engine compartment. The bilge fan was more for keeping the passenger seat cool enough to sit on. Honda eventually installed better insulation so that I don't use the bilge fan much.
Now comes the improvement that I am getting ready to do. Years ago when I was young there were several companies that marketed waterless coolant. Today there is only one, Evans Waterless Coolant. It's a little pricey, by the time I bought 1.5 gallons of coolant, 1 gallon of prep fluid and a Chinese made anti freeze refractometer I'm in it about $140 including tax. I opted to go this route for 2 major reasons: !. The Evans Coolant has a boiling temp of 375 degrees F which is more than 100 degrees higher than anti freeze under extreme pressure. The manufacturer claims that their coolant operates at considerably lower pressures partly because of lower expansion rates. 2. Their coolant does not contain water and so totally inhibits corrosion and does not need to be replaced every 2 to 3 years. The prep fluid is only used on the first fill to help get all the water out of the system and the refractometer is to test and be certain that you got all the water out.
They claim, because there is no better fluid for heat transfer than water, that your machine may run a few degrees hotter than before but since the much higher boiling point prevents hot spots where water based coolant turns to steam, the protection for the engine is much better and operating pressures are much lower. The pioneer 1000 engine holds about 0.8 gallons of coolant so the 1.5 gallons gives me enough for the initial fill plus extra for future top off if needed.
I'll try and keep the thread informed of the performance along with any problems I encounter.
Old Gasser
Herbie
Herbie
86
190
Richmond, TX
Where is the bypass hose you are using?
I just purchased the same temp indicator, but got it with a 25mm inline adaptor, and was going to install it in the inlet or outlet
1590675296003
hose to the radiator.
O
oldgasser
53
77
Arizona
It is the 12 mm (ID) hose that bypasses the thermostat. In the engine diagram the flow arrows are grayed out and it hooks to the water pump. It is easily accessible under the seat. It has full flow when the thermostat is closed and less flow when the thermostat opens. The reason I chose that hose is that the coolant has just exited the engine so it is likely at. Its highest temperature.
O
oldgasser
53
77
Arizona
Looking over the discussions on this thread I just wanted to comment on some of the observations: The radiator cap opens under excess pressure and is not dependent on temp. With the Evans coolant the coolant pressures are not supposed to exceed 5 psi where most high pressure caps are rated at 14 or 15 psi. Evans coolant says it is fine to continue using the 15 psi cap but it is not necessary. Gasoline engines generally run better at higher temps but coolant boiling is a limiting factor so keeping the coolant from boiling, which produces steam (vapor) which further limits cooling as heat can only transfer to liquid coolant, not vapor. By raising the boiling point to 375 degrees F. you are assured of having only liquid in the system and no hot spots where the liquid turns to steam which causes the local heat to get even hotter because it can not be removed from the engine. To me, this is a far superior and less expensive way to eliminate the cooling problem and significantly reduces the chance of hose or gasket failure due to greatly reduced coolant pressures.
O
oldgasser
53
77
Arizona
I downloaded your coolant flow diagram and applied orange hi liter to show the location of the temp sensor. I also inked in a pointer to show the location. I used brass hose barbs 1/2" hose barb x 3/8" mip and threaded the hose barbs into a 3/8" brass pipe tee. In the center leg I used a 3/8" MIP x 1/8" FIP reducer bushing into which I installed the below listed adapter to make it accept the trail tech sensor. As luck would have it the sensor was just the right length to have the end positioned right in the middle of the coolant flow pattern
The link below is for the 1/8" MIP x 1/8" Female BPT adapter.
Old Gasser
Reactions: Herbie
aauman88
aauman88
1,091
2,846
I found it cheaper somewhere but it’s same strap. It’s not going to break. But I only suggest it if you have the SATV frame stiffener. Take the front two spacers out and bolt in place.
