P1000 30-10-14 carnivores
bboatright05
bboatright05
11
17
I want a straight up answer. Will 30-10-14 maxxis carnivores on a 14x7 5+2 wheel work on my 1000-5 deluxe with ONLY the highlifter 2.5 and be functional? And has anyone done this exact setup?
Reactions: Eltobgi and BWAF
67,097
You'll rub alot on tight turns and bumps. A true 28" rubs without forward a arms.
Reactions: Dragon21 and BWAF
64,180
I just finished installing front super atv arms in prperation for 30x14 tires. Was thinking about carnivores too. Running factory wheels with 1" spacers front and 1.5 on rear.
To run 30's with no to very minimum issues you must run front offset arms. Lift is not required but is a nice addition.
With out the arms. You will eat up your front inner wheel wells.
The rears have very light issues on a hard jumps compression but overall will fit.
Reactions: BWAF and Plumber32
bboatright05
bboatright05
11
17
Excellent information. Thanks a lot.
67,097
Check out the pro armor dual threat tires. 10 ply . I've read alot about really weak sidewalls on carnivorous. The reviews on that talked me out of them but they sure look good!
Reactions: BWAF
64,180
Thanks for the info..
I can punch a side wall for sure so strike!
Reactions: Plumber32
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
You think 30s will work on stock wheels with just arms?
It's a thought I have friend that has rzr rock crawler it has different width rims front and back ! Thats stock ! He Runs 30's maybe just find 2 more front wheels and get some spacers
BWAF
BWAF
8,857
42,437
Carthage MO
Im running 235-75r -15 lt on 5x2 sti no lift 1" rear spacer some say they will rub but so far no problems .It's close some I'll put arms on C27b884d3fbb9274eacf02fb73059d965a54d9f71835ff5aa30faf5ebe1aa898D48a529e9b5af07392f09a772c238fb7A0c29663833c8a7a807491d0f335f4a0
