30" tires
39,079
Did you do IGR to run 32s?
I wanted it for the 30 inch Roctanes because they are a true 30 inch tire. We have 30 inch Terrabites on another pioneer 1000 and they measure about 28 1/2 to 29 inches depending on air pressure. It’s not needed for that tire in my opinion.
My 32 inch Terrabites are just over 30 inches tall at 10 psi so they are not much different then the Roctanes. They are lighter however. I was going to put the IGR in even if I kept the other tires so I really didn’t do it specifically for the 32‘s
Reactions: JTW
BigOL3
BigOL3
2,994
8,918
What is ..... IGR?
39,079
You changed out the gears in transmission or front/rear end??
The transmission does not get power straight off the engine. There is a main gear reduction between the engine and transmission. So that’s the single gear that I’ve changed for a lower ratio.
ReductionBoss is the manufacturer and seller of that gear.
Amonzo
Amonzo
47
66
Todd county, Kentucky
Can you notice a big difference in the internal gear reduction? And what's the total cost for everything on the IGR? I have 30 intimidators and would like a 32. But already feel like I lost some power.
39,079
Big difference in low end power.
$950 for gears.
$100-$300 for electrical calibration to get the shifting correct.
If you do just the IGR, it will shift in manual mode exactly like stock but in automatic mode it will hit the rev limiter before shifting if you are applying 90% throttle or more. Some people are OK with that but you can get some signal interceptors to change the input signal from the tone ring in the transmission and front differential to get the shift points back to stock. Then you have to make a little adjustment to one of the shift solenoids to bring the shift pressure back to where it needs to be. It sounds intimidating but it’s actually very easy.
If you’re buying signal interceptors you can also get a third one to put on the rear differential which is the sensor that drives the speedometer. So even with the gear reduction and 32s my speedo and odometer are reading exactly correct.
39,079
I should also say that an additional cost would be an oil change because you are opening up the transmission and it’s a good idea to change the oil one more time after a few miles because you do have to do a little bit of grinding on the transmission case to get the bigger gear to fit.
Reactions: Kilo427 and Amonzo
Amonzo
Amonzo
47
66
Thanks for all the info.
Reactions: joeymt33
BigOL3
BigOL3
2,994
8,918
$950 for gears.
Where did you get the re-calibration done ..... Honda?
39,079
SpeedoDRD
This is used for speedometer calibration and transmission output calibration and the speed sensor in the front differential. The same part number can be used in all three locations.
Reactions: BigOL3
nbomar
nbomar
4,416
17,854
Springdale, AR
SpeedoDRD
This has been my biggest Hangup in not doing the IGR.. the shifting not working like stock afterwards. You’re the first person I know to have done this. That’s cool!
39,079
Snuff is the one that figured it all out so the credit goes to him. He worked pretty hard trying to figure out the different ways to improve it. I just stood there and watched like a vulture and waited for the right time to swoop in and steal the ideas.
Kilo427
Kilo427
1,543
6,439
That is the best thing to do if you are watching snuff work honestly, Otherwise I would just mess everything up then have to wait for him to come up with a fix anyhow lol.
Similar threads
