Is a 3500 lb winch big enough for a 1000 3 seat?
D DUSTMIL New Member Apr 21, 2020 12 11 3 TIPTON IOWA Ownership 1000-3 Jun 23, 2020 #1 Is a 3500 lb winch big enough for a 1000 3 seat?
SWB Well-Known Member Apr 22, 2019 2,013 7,075 113 South Central Arkansas Ownership 700-2 Jun 23, 2020 #2 Would think so? But, my P700-2 has 4500 on it.
Remington POIDH Enforcement Officer Lifetime Member Supporting Member Jul 24, 2016 20,253 115,818 113 Michigan Ownership 1000-5Talon X Jun 23, 2020 #3 Depends on what u might pull with it?
D DUSTMIL New Member Apr 21, 2020 12 11 3 TIPTON IOWA Ownership 1000-3 Jun 23, 2020 #4 Mainly for a plow but if I get stuck will it pull me out?
sporttrac4x4 Well-Known Member Lifetime Member Jan 7, 2016 1,177 2,083 113 ILL. Ownership Other Brand Jun 23, 2020 #5 DUSTMIL said: Is a 3500 lb winch big enough for a 1000 3 seat? Click to expand... No Reactions: ohanacreek
trigger Old Ironsides Vendor Lifetime Member Supporting Member Feb 13, 2016 24,390 182,151 113 Bay City, Michigan www.quickshieldutv.com Ownership 500 Jun 23, 2020 #6 Running a 3500 on a P5, probably need more for a P1.
ToddACimer Pioneer 1005-2 Lifetime Member Oct 7, 2016 3,685 15,587 113 Oshkosh, Wi Ownership 1000-5 Jun 23, 2020 #7 4500 is the smallest I'd go on a P1k Reactions: ohanacreek, sporttrac4x4 and Adam490
R rickoshea Guest Jun 23, 2020 #8 3500 and a snatch block will pull you out.i did it with a 2000 and a snatch block.
Adam490 HFA Grand High Wizard Lifetime Member Supporting Member Apr 7, 2019 8,075 60,949 113 Covington, LA Ownership 1000-5Talon R LV Jun 23, 2020 #9 rickoshea said: 3500 and a snatch block will pull you out.i did it with a 2000 and a snatch block. Click to expand... That depends entirely on what you're "stuck" in. High centered, sure that would do it. Stuck in mud, pulling up a steep incline, through rocks, etc. you'll find the limits of a 3500 very quickly. Like others have mentioned, stick with a 4500-5000. Reactions: sporttrac4x4
R rickoshea Guest Jun 23, 2020 #10 no argument here.i upgraded to a 4500.2k was temporary,but it did work.so will a 3500.if that's what the op already has.
D DUSTMIL New Member Apr 21, 2020 12 11 3 TIPTON IOWA Ownership 1000-3 Jun 25, 2020 #11 I put a 5000 lb on. Thanks for the input everyone! Reactions: sporttrac4x4
