P500 4+3 rim guys step inside...
Ragincajun92
Ragincajun92
163
230
Kingsland, Georgia
Are any of you guys running a 4+3 wheel on your P500? I’m thinking this would be a better option for me over the 5+2 for a wider stance. I don’t have to worry about the 50” trail Requirements where I live and I want a wider more stable ride. If I’m thinking right this will be the same as running a 1.5” spacer on the stock wheels correct? Also will me front tires stick out farther than my rear wheels with the set up? Any pictures with you guys running this offset would be awesome.
Reactions: iowaguy
G
Gassygordo
302
1,025
Fillmore, NY
I am, l’ll take some pics this afternoon when l head up to split wood.
906UP
906UP
13,158
122,977
da Yoop
Here you go, 27" Tusk Terrabites on 4+3 ITP steel wheels
20170721 191722
906UP
906UP
13,158
122,977
da Yoop
I haven't measured the width, handles much better with this set up.
20170805 152947
Reactions: Eltobgi
G
Gassygordo
302
1,025
Fillmore, NY
B5A3F3DE EB77 4895 85EB E1509D46DB81
9EB46AF3 3E55 4A58 BE5D B212D75D311D
ITP wheels with 27” mud lites.
L
lakebear
906UP I am in the market for a set of road tires.. i would like to know if you like them..lots of pavement riding by me and my other choice is Kanati Mongrels. I also would like a wider stance....would you buy again...looking for smooth ride and quieter Thanks
906UP
906UP
13,158
122,977
da Yoop
Absolutely! Most of our riding is forest roads, 2 tracks, gravel with a bit of sand and an occasional mud hole thrown in for good measure. On the hard stuff they're quiet, smooth & handle great. I've been in mud/water holes over the seat and they pulled me through. No complaints with these tires. If I remember correctly these are a DOT rated tire, sorta remind me of BFG Mud T/A's.
Reactions: Gassygordo
Ragincajun92
Ragincajun92
163
230
Kingsland, Georgia
906 may I ask where you got your tires and wheels from that is what I'm looking for but can not find the wheels in 4+3. Thanks for any help
4+3 are hard to find. I ordered some 14” msa diesel wheels today In 4+3
906UP
906UP
13,158
122,977
da Yoop
RMATV, use a Yamaha machine for reference..... Rhino, Wolverine, etc. Same bolt pattern as the P5
Reactions: Ragincajun92
SchockSquad
Nebraska
Does anyone with the 12" ITP Delta Steel 4+3's happen to know the model number they purchased? It seems there's only one that would fit (1221753014), but Dennis Kirk shows the recommended Delta Steels for the P500 as "large bell" and the 4+3 model is not labeled as "large bell".
Neither Dennis Kirk or ITP will confirm if they fit, as they aren't the recommended offset.
Just slightly concerned they would show up and not fit. Looking for a little confidence boost before pulling the trigger.
Thanks.
906UP
906UP
13,158
122,977
da Yoop
Thanks.
Here's the set up I bought, I used a 2012 Yamaha Grizzly 700 in the "tire package finder" on the RMATV site to get the size/offset I wanted. This is the exact package on my P5 pictured above, one note.....don't order the lugnuts this way...they don't fit, wrong thread pitch o_O
Front:
Includes:4/110-Grizzly-550/700 ITP Steel Wheel 12x7 4.0 + 3.0 Black (2 per pkg.)Mfg. [HASHTAG]#1221753014Tusk[/HASHTAG] Terrabite Radial Tire 27x9-12 Medium/Hard Terrain (2 per pkg.)Mfg. #163-021-0001
Rear:
Includes:4/110-Grizzly-550/700 ITP Steel Wheel 12x7 4.0 + 3.0 Black (2 per pkg.)Mfg. [HASHTAG]#1221753014Tusk[/HASHTAG] Terrabite Radial Tire 27x11-12 Medium/Hard Terrain (2 per pkg.)Mfg. #163-021-0002
Total price $617.96 shipped
SchockSquad
Nebraska
Perfect. That's what I needed. Thanks for the heads up on lug nuts. I was planning to use the factory lug nuts, but will look into it a little more.
Going back and forth between 26" Maxxis Bighorns or ITP Blackwaters.
Thanks for the help.
13,458
66,261
Factory Honda lugnuts will not work on aftermarket rims.
Honda has a rounded seat on their nuts. Aftermarket uses a taper style seat.
You don't need to buy them with the rims, but you will need them. Steel wheels I think you can use common off the shelf nuts. If rims are aluminum, you will need spline drive nuts due to hole clearances on rim.
SchockSquad
Nebraska
Thanks for the info. I'll make sure to get some lug nuts ordered or find some locally.
G
GreenBush
40
57
The Motor City !!
20180621 153107 zpsplr3rjkb
20180621 153113 zpsemidbh4m
Literally just got these in today.....Excellent......
Delta 4+3's all the way around and ITP Blackwaters 26x9 and 26x11.....
I'll post pics and a brief report when I get them mounted and a few miles on them for function...I'm sure they'll do just fine and look better... Won't be until after the 4th....dangit...LOL...
