Hey guys. I have a 2018 Honda p5 with 26 inch Duro tires on stock rims. I saw a good deal on A set of rims. They are 6+1 off set, 7 inch wide. All four are the same. Would these add width to my p5 or would they be like stock?
Thanks
Thanks
So 6+1 would be 1 inch out from the hub? And stock is 1 1/2 ? Sound like I need to go the other way to widen my P5. Maybe that’s why the rims were so cheap. ThanksStock off=set is near 1 1/2 inch .5+2's are 2 inches out past the hub face.!" would be a shade narrower than stock.I've not seen 6+1 before.
55 would be a good width. I think I’m at 51 or 52 with the bigger tires I have.Mine are 5-2 rims and I’d think 6-1s would be even better (for stability) not that it’s a huge concern for what I do, can’t remember offset of stockers, sorry. Mine is now I wanna say 55 or 56” wide and just squeezes between the wheel well on my 97 Powerstroke so I’m happy. My continued mantra is Radials tires in 12” rim if you want a smoother ride, 14s if in deep mud. Then shocks like Elkas or W.E.s so changes the ride handling of these little beasts.
4+3 should get you around 53'' to 54'' wide.Also depends on tire width...55
Yep.So 6+1 would be 1 inch out from the hub? And stock is 1 1/2 ? Sound like I need to go the other way to widen my P5. Maybe that’s why the rims were so cheap. Thanks
No worries, think I understand what I need now.Keerap @Jevin, I have misinformed you had that backwards.... I’ll measure mine today as it’s sitting in the truck right now. I’ll double check mine are 5-2s as well. My apologies.
j
6x1 means 6” out 1” spacing out so it would be wider than stock. Someone made a post on this subject.No worries, think I understand what I need now.
