P700 700 front axles problems!!!
Robologger
6
Florida
Anyone have issues with front axles on. 700-4 I have a three inch lift and outlaw2 seems axles are o er extending and coming apart. Am I the only one?
Robologger
6
Florida
Upload 2018 6 17 10 58 45
This is her
motorman18
439
277
Laurel, MS
Iv broke a few axels with less lift then what you have 3 inch is probably pushing it to the limit but aftermarket axle will handle it better
Robologger
6
Florida
It does good until u get in really think stuff but normals it will back out of it if it won’t go through it. What type of aftermarket axles do u recommend ?
motorman18
439
277
Laurel, MS
Haven’t heard of that axel I’m not running aftermarket yet if I break another I’ll probably get a rhino axel
Reactions: Sgt_Dubie
SundayRdr
SundayRdr
575
1,179
McMinville Tn
I'm running SuperAtv Rhino axles and they're better than stock. They are about 1/2" longer, thicker shafts, better boots
Reactions: Tflynn
Billjones617
5
10
IL
Gotta remember OP, factory axles were meant for factory spec'd tires.
If you start changing things, get ready to go aftermarket on the drive train as well.
Reactions: Tflynn
Gator
Gator
The Most Unknown Member
2,475
10,388
Louisiana
I'm running about 5" of lift and so far I haven't broken an axle. I'm sure I will eventually.
Robologger
6
Florida
Mine would only break when I turned all the way after front shocks were fully extended. I just took the bracket portion of my lift off and left the spacer In The shock I am hopeful I still have enough clearance without over extension of the axles which is what I believe was causing them to break. I lost one inch of clearance but I am still sitting at 14 inch’s in the front. I will post a update after I test it out
scott
scott
1,212
1,354
lyman, South Carolina
I’ve had my 700-4 for 4 years now. Haven’t broken a single axle. I ride hard and push it. 27” bear claw HTR and Can Am commander shocks.
Reactions: Mudwing and swsebek
If it can stand up to @scott,....THATS when it’s considered “trail rated”.
He rides HARD but he doesn’t ride to trash the machine.
Cyberjunk
Cyberjunk
Berserker
1,622
6,077
Crane Hill Alabama
Ok so basically I have the same , 27 inch blackwaters and can am shocks, broke both stock front axles and now 3 all balls ? and I drive like a grandma on her way to Sunday brunch with a cake in my lap :)
Reactions: Russ989
Matt99gators
7
Satellite Beach FL
I have 2017 700 with no lift and 27s. My passenger side front axle is pulling out of the Diff. Dont know how or why this is happening. Tapped it back in and looks fine. Wanting to fix permantly,
motorman18
439
277
Laurel, MS
Pull it all way out I bet the ring not on the end to hold it in
Matt99gators
7
Satellite Beach FL
I wasn't aware of any retaining ring holding the axle in..... (Inside the front diff?)
