P1000 80W-90 Gear Oil?
howardjg
howardjg
16
57
Is gl-5 the spec to look for when changing gear oil. Planning to try
Valvoline High Performance SAE 80W-90 Gear Oil 1 QT​
https://www.amazon.com/dp/B001OV61KW?tag=sxsweb24-20
This is a hypoid gear oil. Getting ready to service my machine for the first time, new to me 2017 1000-5. Went to dealer for Oil and filters and forgot the gear oil.
Will consider synthetic the next time I change it.
Thanks in advance
E
Ericthered
Eric The Red
271
522
Sparks, NV
Don't do it! I tried and the shifting was near impossible and the grinding made me flush and reservice with the correct oil. Scared the hell out of me. Tolerances must be tight or gears have to be right against each other, so get correct oil.
Reactions: WagginTail
115,304
You must be thinking he means the sub trans? 🤣 That would suck!
I think and hope he means the rear diff?
115,304
Thanks in advance
If u mean the rear diff your changing? yes that will work. Some unsolicited advise, just a few bucks more and get the Synthetic valvaoine Then u wont have to change it for a very long time and it will be quieter. I did this back in 17 on my 16 and its still a.o.k
Reactions: howardjg and Lady01
Neohio
Neohio
Beast of the East
14,573
73,615
Painesville Ohio
This is a screenshot of the service manual.
1661949956056
Might need to find a picture of the Honda shaft drive oil and see if you can read the specs on it.
