P500 A-ARM KIT ?
195,790
I was corecct @trigger , I went back to check , just to verify!
So it says you can get just the fronts, so it's moving it forward to clear for bigger tires? Does it lift it at all? Will factory shocks/WE still work? The rear doesn't need to be moved, is that just to lengthen the wheel base? That dude needs to get on here, I'd love to see some pics and get some specifics!
Chooglin
I don't know much about them but just from looking at the pics of the A-arms , I would say YES to all of your questions!
Chooglin
You wouldn't want to lift the front and not the rear though, it must not be much? If this would allow for 28's comfortably...and you could get them in black...hmm
@trigger it sounds like it doesn't increase the height/lift any but does give more ground clearance because of the arch in the bottom A-arm. You should.be able to get just the fronts without changing the height , front to rear !
Screenshot 2019 01 10 21 08 04
Duckhunt
I just trolled their page using the wife's account. These look pretty BA! It would also mean a new set of tires too though...and the spare. Geez, this would be expensive! I still want them though. :rolleyes:
That's fricken hilarious I got What's her face to log in on my laptop to Facebook so I can go to all the millennial websites without that stupid "LOGIN OR JOIN FACEBOOK" popup blocking my view. And for the record I'm technically a millennial by 1.5 months.
Reactions: Todd627 and trigger
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
and with all of this to add bigger tires to raise center of gravity and increase roll overs or just go taller and wider with my kits
20190110 161956
195,790
I got in touch with the thro facebbbook Their phone # 325-725-3994
I called this guy today, his name is Joe. Came across as a good guy and knows his sh**. He just got out of the military and started this business with a buddy. He said they make stuff for the popos and others but couldn't believe how the stuff they've started making for the P5 exploded. He said the A arms are made to order and can be powder coated any color you want. They bolt right on with all the factory equipment and move it forward enough to accommodate 31" tires comfortably. He said some guys are running 33's. Stated that it doesn't lift it much at all, maybe a 1/2". Asked him about the upper tab support they make too, said it comes with self lubricating bushings and bolts in over existing tabs. They're a small shop right now but, after talking with him, they're going to grow fast. Said they've invested in a CNC machine too.
Didn't order today but can see it's coming...:cool:
Chooglin
Thanks for the feedback on these
Reactions: trigger
jamesparisp5
North Carolina
maddmax
257
231
Clarksdale Ms.
Should have mine this weekend.I'm gona pass up the last weekend of deer season here just to install them.
Well it's been a long 10 days I orderd my a-arms on the 4th and getting them today on the 31 . got new ball joints from All Balls ready to install.Just hoping they install without any problems.Good luck to me self.
195,790
Following this. Keep us posted Max. ;)
