P500 A tip for cleaning your filthy P500
ehart814
ehart814
1,654
3,643
NWPA
I've been using this for a while, so I thought I'd share. I bought this stuff at Home Depot for cleaning the garage floor when I spill oil. I found that it works very well to get mud off of quads.
E71e36542aaff2aa6f4a67fde1f73e1c
First step. Get a spray bottle and dilute it with water!!! It's surprisingly strong and I don't know what kind of damage it could cause if used straight. I sprayed down the mini Chinese quad with it, and the shiny silver frame and rack paint turned to a matte finish! (Really cheap paint, obviously)
Spray this stuff on the mud and let it sit for a minute. Then spray it with the hose. It will really help get the mud off.
Best part, it's cheap! I think around $13 for the gallon if I remember right... And it really is a time saver. A gallon will last a long time.
I strongly avoid getting this stuff on the windshield. Other than that, I use it everywhere.
Just remember to dilute it! I assumed it would be weak because I bought it at Home Depot, but it is very strong stuff.
64,288
Awsome. Thanks for sharing. Seems there are several cleaners just like that that work WONDERS!
I have been impressed with a few different ones. I will give this one a try now as I am currently out.
Thanks.
ehart814
ehart814
1,654
3,643
NWPA
Thanks.
Hondabrite is great stuff but it's very expensive. I'd buy 10 gallons of it if it was $13 a gallon. Hopefully others will find this Zep stuff useful.
Reactions: Hondasxs
Castrol Super Clean is another great product. It's $8 dollars at Walmart. Thanks for the tip on the product from lowes.
My vehicle went from really dirty after riding Royal Blue to looking like this
A9fb6cfe34e02ac839f527f2765d19b0
I rinsed the mud off, sprayed super clean on using a pump up sprayer and rinsed it off. I'd say it does real good. Try cutting with water 50/50. I sprayed everything, the windshield, rear fabric panel, dash, etc.
Sent from my iPhone 10s
34,174
I can only wash mine at a car wash. I wonder if it could be used from a Hudson sprayer and then washed off??
ehart814
ehart814
1,654
3,643
NWPA
I don't see why not. I'd think that would actually work even better than a little spray bottle.
Reactions: Montecresto
Code54
Code54
583
626
Hurricane West Virginia
Those little one gallon garden sprayers work great!
I personally soak my machine down first then hit it with the chemical cleaner and it seems to help break the bond a bit better
34,174
I'll give it a go and report to you.
Madore128
175
291
Ma
Mr clean. (The yellow stuff) works awesome. An safe on everything. Been using it for year to wash my pro motocross bikes.
Code54
Code54
583
626
If you have access to hot water that helps a TON. I don't do it every single time but sometimes I hook up the hot water power washer and really clean the machine. Gets mud off no problem and if you have any oil or grease anywhere it basically melts it right off.
You are right! Hot water helps a lot. I also tapped into hot water at my house. I have two spigots next to each other for hot and cold.
Also, I have the tankless water heater so I can use hot water forever...at a price.
Code54
Code54
583
626
Sure does - one of the best "tools" i have bought for around the house. I can get up to 220 degrees (basically steam) but mostly run around 180-200. I do the car motors every few months and they stay looking like new!
