Chooglin
Ordered some stuff , so I can get all my accessory wires under the hood !!
Are you doing a dual battery install?Ordered some stuff , so I can get all my accessory wires under the hood !!
No, not right now anyway.if I do go with dual in the future , I will need to buy a new switch !!Are you doing a dual battery install?
Ya mine is filling up also , there just isn't much room inside the battery box. I want to add a light bar ,so I figured now is the time for me to do this !!!Looks like you're doing it right. I need to do this too, I can't fit one more wire on my battery!
I suppose you could piggy back off of it, but why wouldn't you get supply from your Blue Sea box, and be properly fused?Is there any reason why I shouldn't get my power for the switch and fuse block , from the winch contactor ?
The main power needs to go to the switch and then to the fuse block, so I would just come off the contactor ,to switch then t0 the fuse block !!!I suppose you could piggy back off of it, but why wouldn't you get supply from your Blue Sea box, and be properly fused?
Thanks for the suggestion! !!That's is what I am going to do with mine. The only other thing I would add is a breaker or fuse from the disconnect to the fuse panel. Looks like alot of guys are using the Bussman Breakers between 60-80 amps. Just a suggestion.
I have 100Amp circuit breakers on the 6 gauge + wires.Thanks for the suggestion! !!
Nice and neat.. I like that you put the voltmeter and switch under the hood! You want to come do mine?if it looks like this when you're done, it will all work.
//hondasxs.com/attachments/image-jpeg.11117/
That looks very nice. Very clean. So I'm guessing this question answers itself, but the switch is just so nothing draws when machine is off in place of keyed power right? Since it looks to be directly from the battery?I have everything mounted and hooked up , now all I need to do is add a breaker !!!
This is going to make it so much easier to add accessories.............no more running wires back to the battery !!!
View attachment 12220 View attachment 12221
Exactly! !That looks very nice. Very clean. So I'm guessing this question answers itself, but the switch is just so nothing draws hen machine is off in place of keyed power right? Since it looks to be directly from the battery?
Haha, negative. Btw, the voltmeter is in the dash, the battery switch is under the hood. I have dual batteries.Nice and neat.. I like that you put the voltmeter and switch under the hood! You want to come do mine?
