P1000 Accessory Issues - Any Insight?
Luckybeer
Luckybeer
24
48
Canada
Hello, wondering if anyone has issues like this:
I have a 2019 LE, I put a second battery on her with an isolator kit etc. On the second battery I have a 54" LED light bar, and a 700W stereo. When I run the SXS and have the light bar and/or the stereo, both or just one.. the second battery only lasts about 1hr or so.. Shouldnt the second battery be getting a charge off the main system after voltage drops to a certain level? I have verified the setup is correct.. Any thoughts would be great! thanks
Ultrasonic1
Ultrasonic1
206
766
Nomadic
First off, welcome to the club! I can already tell you have pictures the rest of us would love to see! Do you mind drawing out a diagram of your wiring? If everything is for sure wired right I’d suspect a failing component somewhere.
Reactions: TripleB and Isaiah
TripleB
TripleB
15,241
136,125
Caryville, Tennessee
Do u have a dual volt meter Guage in your machine?
Luckybeer
Luckybeer
24
48
Canada
Hello all, I will take alook and draw the wiring out for you. I do not have a dual volt meter, only one for the main battery. I will also get some pictures together for everyone!! Lol Thanks again
BBLASER
159
277
Phoenix
If the voltage drops below 12.9 volts when the batteries are tied together, the isolator will isolate the batteries until the voltage is above 12.9 for 10 seconds. Basically, your second battery is drawing down so low that the isolator sees them as low voltage when they are in parallel. Sounds like your stereo is drawing too much amperage.
Reactions: Tip and Ultrasonic1
Luckybeer
Luckybeer
24
48
Canada
Hi BBlaser, I was thinking that, but I can have the stereo off and just use the led light bar. The light bar will only last for about an hour, maybe hour and ahalf. Here are some pictures of the wiring and my rig.. I hope you can make it out good enough..Yes we still have about 2 feet of snow. LOL
IMG 0576 IMG 0575 IMG 0574 IMG 0573 IMG 0572 IMG 0571
70Bones
70Bones
888
3,779
New Brunswick Canada
You are simply using more power than your alternator can produce. A LOT more. Once the battery dies, you need to shut everything down to let the batteries recharge.
Reactions: Isaiah
TripleB
TripleB
15,241
136,125
Does th
View attachment 197637 View attachment 197638 View attachment 197639 View attachment 197640 View attachment 197641 View attachment 197642
Does the blue light on the isolator come on when the machine is running?
Reactions: Ultrasonic1
Luckybeer
Luckybeer
24
48
Canada
70Bones, I think your right.. drawing too much power.. Is there bigger alternators options for the Pioneer?
Ultrasonic1
Ultrasonic1
206
766
Nomadic
I have a yellow top optima battery under the driver seat for my AUX battery. All of my accessories run through it. I could jump start my 1 Ton pickup with my buggy if I needed to.
Luckybeer
Luckybeer
24
48
Canada
Nice.. Maybe I'll go that way.. Thanks for all your help!! Cheers
Russ989
Russ989
22,642
147,257
Yes the blue light comes on when it is running, I also notice it can also be on for a while when the machine is off
That’s all normal, my isolator light will stay on for a half hour sometimes. What’s the rating on your second battery? I wouldn’t think your radio, light bar or the combination of the two could kill your second battery in an hour while running. The 1000 puts out quite a bit of charge.
Luckybeer
Luckybeer
24
48
Canada
That’s all normal, my isolator light will stay on for a half hour sometimes. What the rating on your second battery? I wouldn’t think your radio, light bar or the combination of the two could kill your second battery in an hour while running. The 1000 puts out quite a bit of charge.
I'll check, Off hand I do know that I had to up my fuse for my light bar to a 20amp.. so she does draw some power
5,425
24,913
As inexpensive as digital voltmeters are, they're a no brainer with a second battery. I wired mine to a toggle switch and key on source. That way I can check the battery voltage without turning the key on. When I add a second battery, it will get its own VM.
VM and Ryco emergency flashers on my Talon
I R3jGfpT M
Russ989
Russ989
22,642
147,257
The 1000 puts out 600 watts, here’s a link of a short conversation about it.
66,869
Tell me what this is?
It looks like you are grounding to the this selonide post?
If so.. this is the issue. And also your lucky its not blown up by now.
This seloinde is the starter seloinde and a HOT
BOTH SIDES SHOULD BE CONSODERED HOT.
Second side is only hot when you start it.
Unkook that asap. 2c323db4099fe0caaebdf9bd8ed614bc
Luckybeer
Luckybeer
24
48
Canada
Unkook that asap. View attachment 197675
Thank you, I will check this out asap.. If she is on the solenoid I will remove it.. Thanks
ehart814
ehart814
1,653
3,631
NWPA
When I first set up my dual battery over the winter, I noticed that I could very quickly drain the second battery to the point where the winch wouldn't operate. My winch runs off the aux battery.... I was only running the machine for a little while at a time and it wasn't enough to charge up the aux battery enough. I put it on a charger over night and it was much better after getting a full charge. Now that the weather is warmed up, it gets charged a lot more because I run it for longer periods of time.
Reactions: Luckybeer
