Tell me what this is?
It looks like you are grounding to the this selonide post?
If so.. this is the issue. And also your lucky its not blown up by now.
This seloinde is the starter seloinde and a HOT
BOTH SIDES SHOULD BE CONSODERED HOT.
Second side is only hot when you start it.
Unkook that asap. View attachment 197675
Hi Hondasxs, Here are the pictures I promised before I disconnected it.. The Neg of the second battery and the ground of the isolator were both connected to the solenoid.. check the pictures out.. Is there any other place I shouldnt hook them up to? what would you suggest? Thanks again.. I had no Idea..
