P1000m5 Adam490's Short Bus
THEOLDMAN
THEOLDMAN
238
351
Washington, North Carolina
Got the springs on and they feel so much better than the progressive Fox springs. Need to get out on some trails to figure out where I want the preload, but so far they feel a lot better. Tried 4 different spring compressors before I just gave up and went to the old hillbilly spring compressor. The progressive springs were coiled too tight to get the compressors to work without destroying the plastic spacer they ride on.
What is the weight of the springs that come on the fox shocks?
Reactions: Russ989
62,510
What is the part number of the lights?
These are the lights (they were $12.99 at my local TSC, not $25 as listed online). Not sure I'd spend $25 on them honestly, since you are getting close in price to the much brighter lights available on Amazon/eBay. I haven't had a chance to try them out yet on a dark trail but if they suck I'll just put them on my kids Power Wheel.
Bully Truck Bed LED Lights
Upload 2020 1 23 9 45 5
Reactions: Bad_bowtie
62,510
This is the stock rear QS3 spring information for a P1k5:
(Thanks @AZRocks )
QS3 rear shocks for 1000-5: (1000-3 shocks are different)
Fox part# 52400-HL4-M41 etched on lower mount
15.25" free spring length
8.52" of travel (solid length: 15.25-8.52=6.73") (Fox could not confirm solid length, but did say the travel was 8.52")
6.1" Shaft stroke
187-350 lbs progressive rate
Russ989
Russ989
22,645
147,291
211,850
No idea, I've never seen or run them. I think @Smitty335 ran them before and destroyed a couple if I remember correctly.
Not me, I ran the stockers for a little while then EFX's, then Black Water's and now Tera Bites
211,850
I thought it was an EFX Moto Claw...
Think they were Moto Hammers, Montie has them now. They are great tires, I was running the stock size front tires on the stock rims, just not enough tire size for aggressive riding.
Reactions: Adam490
62,510
Ah okay cool. Didn't realize they even made the Moto hammer. Those do look pretty good! Thanks for chiming in
62,510
Got a few small things done today while I was "working from home"...
New OTRATTW switch covers, still need to hook up fan override switch
IMG 20200130 142712
New winch pull to replace my old one that flew off somewhere along the way home from TN
IMG 20200130 190633
Installed new 12" light bar
IMG 20200130 163402
Didn't realize it had a DRL mode, but turning it off and on quickly puts it in DRL mode
IMG 20200130 163436
Russ989
Russ989
22,645
147,291
Similar threads
