P1000m5 Adam490's Short Bus
62,346
Yea you get those springs cranked back and then it dawns on you just how wrong it could go
Absolutely. I got them back just enough to get the retainer off then threw a couple wet towels over it and hit the ratchet with the handle from the jack. I thought I'd just bump it with a little piece of 2x4 on the first one and it blew the bottom out of the bucket when it released. The new 300# went on easy.
THEOLDMAN
THEOLDMAN
238
351
Washington, North Carolina
I put some reptile eye perforated vinyl skins from @thevinylcreator (Kent Hill) on the other day and they look pretty cool. They definitely cut down on your light output so I'll probably pull them off for a night ride on tight/new trails, but they are fine for cruising the hood and around the farm. If you have a lightbar/pods you would probably be fine with them on. Maybe this can be my excuse to add the lightbar...
Can you take them off and put them back on?
THEOLDMAN
THEOLDMAN
238
351
THEOLDMAN
THEOLDMAN
238
351
Astra Depot 50' x 1/4" RED 7000lbs Strong Synthetic Winch Rope Rock and All Heat Guard + Rubber Stopper + Red Heavy Duty Half-Linked Hook for Truck ATV UTV KFI https://www.amazon.com/dp/B079L32WV9/?tag=sxsweb24-20
That’s one I’m using now and it looks identical. I haven’t pulled real hard on it and probably don’t need to
How is your winch line holding up I purchased the same one
THEOLDMAN
THEOLDMAN
238
351
@Plumber32 are you still running Rock-a-billy's? I'm liking that tread pattern. Tried searching but only found a few older posts where you said you liked yours and @nbomar said he didn't like them. Too many damn tire choices.....
How are the MOTO CLAW 30x10x14
Reactions: Russ989
Similar threads
