P1000m5 Adam490's Short Bus
212,805
I've got a bunch drilled in mine along the frame rails. Thick mud just stays though.
I use the grain bin virbrators going up the next step hill!
Reactions: Isaiah
63,031
Was picking up some shingles to roof my shed and saw this stuff that looked like it would work perfect in our snorkel heads to keep trash out. It's similar to the stock foam block that sits in the intake under the hood to keep trash out. I just cut off a chunk and smushed it into the snorkel head then screwed the cover back on. No issues with power loss or anything as it's pretty porous:
@joeymt33 @Plumber32 @ohanacreek @ToddACimer @Ohio4x4 @Ridinfool @GlockMeister
1602005470625
1602005154883
1602005166017
63,031
Stumbled across these monoprice.com brand dry bags the other day when they had them on sale. I got 3 20L bags and a 10L. They appear to be a similar construction to the $50 Sealand bag I bought to keep my compressor in, but I paid less than $50 for 4 of these. Planning to use the 20L for clothing on overland trips.
PXL 20201013 221312325
PXL 20201013 221319936
63,031
Finally got around to swapping out the worn SATV bushings in my front arms. Every one of them was trash, probably close to 1k miles with the arms on and I probably should have replaced them at 250 miles with how poorly those bushings held up. Feels like a new machine now that I put the RB3 bushings in and everything took grease like it was supposed to.
1606246536384
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
Why did you buy RB3 bushings vs garage products?
Reactions: JenElio
63,031
Didn't know about the garage products. I have had the RB3 sitting in the box since before my last Tackett trip, just never got around to installing. I'm planning on picking up a set of the garage products for the rears.
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
I was trying to decide between the 2. I need to replace my fronts pretty soon and I have a lead on a set of rears. Garage products is currently sold out.
Reactions: JenElio and Isaiah
63,031
The RB3 bushings are nice. I've never seen or handled the garage products sets to compare, but I've heard nothing but good things. The SATV bushings are junk so you'll be hard pressed to find something worse!
JenElio
JenElio
82,862
718,214
Loxahatchee, florida
I'm getting ready for these A-arm bushings as well, got quoted $300 for (front and rear) set from garage products vs. $190 from RB3
Don't know how much better GP is but that's a big difference in $
63,031
As long as you don't use the SATV bushings I don't think you can go wrong.
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
I can not speak to the RB3 bushings but the Garage products are top notch. I replaced both front and back and it literally stopped all the squeaking in my machine. I have the SATV arms and I am one that actually was able to get grease to go into the arms but a set of their bushings never lasted long. Garage Products are lifetime guarantee. if they fail you send it back so the guy can inspect them (cause he wants to find out what he should improve) and he will send you new ones. @GlockMeister is using them too
Similar threads
