P1000m5 Adam490's Short Bus
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
It's alive! Just went and romped on it going back and forth between high and low. No issues at all and engagement is rock solid now going to low 👍🏻
After I had my low replaced mine felt way more solid .. better than when it was new. Glad everything worked out for you And you were able to do yourself
56,773
Got the shifter brace welded back in. Throwing the skids back on tonight and she'll be ready to roll
PXL 20210422 224406308
PXL 20210422 233439284
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
I like the extra protection 👌
But I would of welded a couple tabs on the frame and bolted it in you will have some choice thoughts about the individual that welded it in when you go to pull the sub trans out again. 😁
56,773
Already had to cut it out the first time :)... Sawzall wasn't skeered.
Haldog77
Haldog77
NTC's Mafia Enforcer
31,238
286,741
Bossier City, Louisiana
Hey @Adam490, I have a feeling my fox shocks are flat. I was reading on page 24 of your short bus build where you fixed yours. Could you explain how or where you fixed your shocks so I can fix mine. Thanks
56,773
Think you may have been on somebody else's build page. Page 24 on mine doesn't have anything about shocks. I've never done anything to mine except change the rear springs and add preload.
Reactions: Haldog77
Haldog77
Haldog77
31,238
286,741
You are right. It was on your page 22 or 23 of your pages that @GlockMeister had a link to the shock rebuild. Sorry to bother you.
56,773
Haha, thought that might be what you were referring to when you said yours felt flat. I never upgraded to the Schrader caps on mine, but I will when they lose enough charge that I can tell the difference. How long have you had yours?
Haldog77
Haldog77
31,238
286,741
I got it in early 2018. It is a 2017 model. Pioneer 1000 LE 3
Haldog77
Haldog77
31,238
286,741
Gotcha. If you can't feel a solid "click" when you switch between the 3 different modes it's usually a tell tale sign that they need a recharge.
I'll double check when I go home today but I think they need nitrogen. It won't do any good if the valves a leaking. I had thought about asking S3 Power Sports here in Shreveport because they build all of these racing machines, and they would know about shocks. We do zinc plating for them.
56,773
Little Takeover damage to recover from. Caught a stump or a root through the side of the tunnel near the front of the machine Saturday night headed to Trail 9:
1623291882156
New floor panel is $81 and I'll reinforce that whole area once it comes in. Had a passenger at the time so it could have been a lot worse had it been a log/stick that got through there. Luckily it just cracked the floor when it hit and missed the wire loom.
Took out my 2nd tie-rod in 2097 miles:
1623292170646
Had a blast meeting new faces and riding with old friends!
tdhanses
tdhanses
1,044
3,553
Kansas
Do you not have a skid plate? The damage looks to be where it would be protected and not in the firewall area, looks like you can see to the floor through the damage.
BigOL3
BigOL3
2,994
8,919
That could have been bad Adam. Glad it was no worse than a little plastic.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Glad you escaped unscathed. That couldve been very bad.
56,773
Absolutely have a skid plate,. It came through where the wire loom runs into the floor section. Looks like the tire may have pushed whatever it was towards the inside and it hung on the flat corner of the tunnel. You can still see some of the wood on the wire loom here:
1623339712812
This is where it came through. Skid isn't going to stop that. You'd need to have something covering the firewall and into the tunnel. I'm going to add some protection to that area for sure when the new floor panel comes in:
1623339879581
