P500 Adding a fused power panel
MarkAlan
Huntsville, AL
I would like to add a Blue Sea fused power distribution panel to run lights and such. When you guys have added blocks and fuse panels, are you using a relay or something that the power cable from the battery would tie into, and switching it on and off with a Key On power to the relay? This would kill power to the distribution portion when the key was turned off. If not are you leaving the panel hot, with a inline breaker, and using Key On to the relays to turn on the lights and off.
Reactions: Mudder
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,498
I use a Bussmann waterproof switched circuit breaker for the high amp stuff. Using the OEM subharness for key on power sources for winch and power steering relays.
9DF13852 15BD 43E2 8466 9726D1C0767D
Hillbillytnt
Hillbillytnt
552
2,030
Ky
80amp stinger between battery and fuse box using the clubs key on harness. That gives you a key on only fuse box
