P1000 Adding a second battery
How do I add an additional battery and isolate with the "Honda SWITCH PLATE HARNESS Part # 0SA30-HL4-100" ?
Just got a SxS10005mD - ordered the switch plate Harness, the "Honda FUSE BOX RELO BKT Part # 0SA30-HL4-100B" relocation bracket, ordered a KFI Winch Kit (Part [HASHTAG]#U4500[/HASHTAG] and [HASHTAG]#101285[/HASHTAG]) & Plow Kit (KFI# 105740, 105635 & 105072). I plan on adding a front light bar, rear LED cubes, a dome light and rewire the winch switch into the panel (using www.otrattw.net switches) and a radio into the power mix.
Just wondering if I add an additional battery what isolator should I use and what should I keep in mind so I wire it so it separates the the switch plate harness and radio off the main battery circuit ?
Great Machine and Most Appreciative of any/all advice !
The Honda switch plate comes with its one PDM module which contains the fuses and relays. It needs to be connected to a pos and neg battery terminal. if you have two batteries, it will be your choice as to which battery you want to hook it to.
I like the True isolator.
Reactions: CumminsPusher
cwalton
cwalton
Who has more fun!
334
724
West Virginia
I also use the True isolator and an Odyssey battery. 1000 miles, with lots of music/refreshment breaks and no issues.
Dallasaero
Dallasaero
16
12
Poplar MT
I understand all about second batterys and isolators, as I have a houseboat, but my question is, how is everyone securing the second battery into the box. I purchased the 925 battery so it fits quite snugly in the box, however it can and will bounce up without a hold down strap.
sharp
sharp
3,757
14,955
Tennessee
Waterproof Velcro on the bottom or side will hold it in place just fine.
Dirtstiffs-1000
Dirtstiffs-1000
1,566
5,708
hondasxs.com
Good day,
New to the forum and the Pioneer 1000.
I just bought an 18 1000 5 LE.
I'm adding a second battery. Just so happened I had a new spare Yuasa motorcycle battery that fits like a glove.
Yuasa GYZ32HL- 500 CCA 32AH
It's a work horse of a battery.
I've also purchased a True Isolator.
I'm just arm chair mechanicing to ask where is a good chassis ground to hook up the second battery and the isolator?
Thanks
And sorry about a redundant question.
Jim
Reactions: TheHoover
TheHoover
TheHoover
221
694
PNW
hondasxs.com
Check the last posts of my build.
P1000 - SuperBee build
I used the factory spare ground(taped up on the side under hood), Tru, Stinger, and BlueSeas fuse panel.
FBD7D489 D945 4923 BCBB 93BA81DD708C
Dirtstiffs-1000
Dirtstiffs-1000
1,566
5,708
hondasxs.com
Good day,
Thanks
Jim
Installed the Isolater to my second battery today, it works perfectly. My LE didnt seem to have a ground point handy like Hoover, so I drilled and tapped one under the left firewall. It will also simplify my fuse box and switch installation.
More to come when I get all my parts.
I also installed a dome/rear bed/backup light as well.
Thanks
Jim
20190216 132924
Dirtstiffs-1000
Dirtstiffs-1000
1,566
5,708
hondasxs.com
Thanks
JimView attachment 108942
20190217 160224
Reactions: Montecresto
Rubin
Rubin
45
170
Canada
Battery is under the seat isolation switch on the dash works excellent D94C90F9 1079 4E9A A52A FD42A12079B9AAE66894 0B51 421C BADD 045BCEE367C2D94C90F9 1079 4E9A A52A FD42A12079B9AAE66894 0B51 421C BADD 045BCEE367C26E4E40C3 0764 4510 A9C0 32D0A247201A 80FE4417 DC23 4543 9B5A 51C8FDEC836F B6FB406D 2647 4F92 8BC2 1687A673DB81 FB13E5AE BD73 4890 917B 5018E6ED4055
Reactions: TripleB
BamaDave
39
112
South Alabama
What gauge wire are y’all using between you two batteries and your Stinger and True isolator? Thanks! David
bumperm
bumperm
1,851
6,658
Gardnerville, NV
Tru includes 4 AWG (conductor diameter .228") with their kit. I used 2 AWG (.3" diameter) when I was making up my between battery ground cable or when the Tru provided cable wasn't long enough. I also shortened their cables when there was excess, as I mounted the Tru between the batteries the cables were short.
20210725 154202
Reactions: BamaDave
