P1000 After Market LED light kit
ScottD
ScottD
6
7
Texas
I am looking to upgrade my stock headlights. Dealer wants almost $700 to put in LED headlights. I found a LED headlight conversion kit on ebay, has anyone had any experience with this? Here is the ebay link, they also said the stock light wire harness will work
Reactions: Isaiah and TxDoc
Gabbas
Gabbas
280
700
Humboldt, Iowa
As Vike's said. Upgrade the base model to LED makes a world of a difference. This is with The vinyl headlight covers on. Stock vs led in daylight. 5e2b94b51d4df658f615421cf80ef668
Sent from my Pixel 4 using Tapatalk
JenElio
JenElio
65,888
614,351
Loxahatchee, florida
I would advise like what has been said already. Put some l.e.d bulbs in you housing and use the rest of the $$ on some light bars/cube/pod. You'll end up with better light output.
JenElio
JenElio
65,888
614,351
As Vike's said. Upgrade the base model to LED makes a world of a difference. This is with The vinyl headlight covers on. Stock vs led in daylight. View attachment 237860
What kind/size wheels and tires you got up front? They look wide(er) then normal. Looks good
Reactions: ScottD and Isaiah
ScottD
ScottD
6
7
Texas
Reactions: Isaiah
ScottD
ScottD
6
7
Texas
Reactions: Isaiah
Gabbas
Gabbas
280
700
Humboldt, Iowa
I appreciate the replies. I just wanted to make sure this is the right bulb for my P1K5 2016. Currently you link has a 20% off coupon so I want to order ASAP. It is the H13 bulb that fits our rides?
Correct. Same ones I have
Reactions: Isaiah
TexasTodd
10
Texas
How does it plug in? It appears to have a round base with the heat sink, whereas our plugs are oval, not round. Maybe I am missing something.
Referring to the Auxbeam H13 bulb listed above by @Gabbas
