P700 Aftermarket exhaust
Terry
Terry
10
10
Arkansas
wanting to replace exhaust with an aftermarket slip on, will I need a tuner or will just replacing exhaust be fine?
1rooster
1rooster
197
203
Fitzgerald Georgia
What year model ? From my understanding if you don't have o2 censors in your exhaust you may have to. But if you do have censors it will correct the lean/rich mixtures itself.
Terry
Terry
10
10
Arkansas
Yeah I just read where 2014 you have to have a tuner but 2015-2017 you don’t need one.
hete
1rooster
1rooster
197
203
Fitzgerald Georgia
What brand slip on you wanting? I'd like to get me one one day if I can find one for a good price
Reactions: Farmer
Tflynn
Tflynn
Not a liberal
2,501
3,834
Northern California
I have a 2014 with a Yoshimura pipe and no tuner. I've put about 5000 miles on it with this setup and no problems, runs great
Reactions: 1rooster
Rinconruss
Rinconruss
40
64
Lakeland Florida
Just an FYI... If you run in any water, do not change the pipe or tip. A larger tip or pipe allows water to get into the exhaust, even if the engine is running. The water will create enough back pressure that the engine will stall and water can flow into the cylinder. The stock pipe creates enough pressure that water will stay out as long as the engine is running.
1rooster
1rooster
197
203
Fitzgerald Georgia
IMG 4718
That is true. I ran a hmf on my big bear for a couple of years without any issues. I could idle under water for hours and never had any shut offs but I had other buddy's that would randomly shut off and have to be drained.
Dan101
Lakeport CA.
HMF Titan black with quiet insert
I'm thinking the same way to go. Want to quiet it down even more to slip up on the wild boars. Any idea of cost? I have a 2018 deluxe 700 and just getting ready for the first tune up.
