P
I am still waiting for my Honda Talon, but hearing Honda has a problem with having to change their air filters. Has anyone addressed this problem? And if so, what is the general consensus for curing that problem. Thank You.
There is a relocation kit. 10-80 dirt sports (or something like that) created and sells. Looks good and provides a prefilter that peeps seem to be happy with. I’ll see if I can find you his member name.I am still waiting for my Honda Talon, but hearing Honda has a problem with having to change their air filters. Has anyone addressed this problem? And if so, what is the general consensus for curing that problem. Thank You.
How long is still?am still waiting for my Honda Talon
I ran the Honda accessories S&B particle separator for a yr, worked OK....ish. Switched to 10-80's set up this year and it's much improved. I did just switch out the Desert Kraft filter for an oiled Unifilter to see if it will be even better. My stock filter was dirtier than I expected at 1500 mile but it has more to do with the dust we've been riding in this year.I am still waiting for my Honda Talon, but hearing Honda has a problem with having to change their air filters. Has anyone addressed this problem? And if so, what is the general consensus for curing that problem. Thank You.
Do you have a link for what you installed? ThanksI put a restriction gauge on my air box and it tells me if the OEM filter needs changing and so far it has no need to be changed.
How long is still?
Filter Minder® - Highest Quality Indicators, Gauges, Switches and Sensors You install it on the air box cover,,, works like a charm, you can get fancy and get one that has a gauge that you put on your dash inside the cabin. My 02 Ford 250 diesel has one from the factory that sends a signal to my dash.Do you have a link for what you installed? Thanks
Filter Minder® - Highest Quality Indicators, Gauges, Switches and Sensors You install it on the air box cover,,, works like a charm, you can get fancy and get one that has a gauge that you put on your dash inside the cabin. My 02 Ford 250 diesel has one from the factory that sends a signal to my dash. You want the grommet mount filter gauge that goes in the air box cover.
What does that have to do withFilter Minder® - Highest Quality Indicators, Gauges, Switches and Sensors You install it on the air box cover,,, works like a charm, you can get fancy and get one that has a gauge that you put on your dash inside the cabin. My 02 Ford 250 diesel has one from the factory that sends a signal to my dash.
