A
If you have an inspection camera to check the condition of the OEM air filter without having to remove it, what are you using? I bought the Harbor Freight camera and immediately returned it. Thanks.
I tried 2 of those. Both failed in a short time. Not sure why but they wouldn't trigger and I could suck air through the diaphragm.Google ''filter minder'' Install it on the air box cover, It will indicate when you have some restriction and then you do your filter maintenance. You can install it in a few minutes and you are good to go. If you want to get fancy you can purchase a style that has a gauge on your dash and impress your friends with that.
I have one from Brian ( 10-80 Sport )and it is the only way to go to solve the wretched Honda filter designAdd a 10-80 Dirt Sports pre-filter kit next time you change the stock filter and you will never have to open the airbox again.
Not that its hard, just a pain. 10 clips and 8 bolts just to check the filter, plus possibly disturbing the seal. A good camera would make it a lot easier.Why dont u want to remove it?
its easy to do.
BTW that HF camera is a POCS
I have a BVC pre-filter and love it. Just would like to peek at the stock filter without removing it.They are easy to check, however I'd highly suggest a particle separator! I use a KWT and couldn't be happier!
Sent from my SM-N975U using Tapatalk
Thank you. I will try it out.Don't expect too much from a tiny camera.
I own 2 cameras. One is an old Milwaukee with a built in screen. Great for it's time but somewhat limited with the tiny screen. Probably cost me a fortune when I bought it 20 years ago but I don't remember how much.
The other is a USB Chinese Amazon unit I purchased to look through the tiny spark plug holes. Bought it as a use and toss expecting it to be a POS but it turned out to be way better than my Milwaukee so I kept it. So far it has served me well...
Fair enough!Not that its hard, just a pain. 10 clips and 8 bolts just to check the filter, plus possibly disturbing the seal. A good camera would make it a lot easier.
