Russ989
They aren’t called the stealership for nothing.
Yes. Sounds right. Just had my 1000-5 serviced at 100 miles for $400.Hi,
I took my Pioneer 1000 (3 seater) in for minor service since it had 100 miles and a year of age on it, and also to check why it sometimes wouldn't go into low, especially in very cold weather. I know now that's a linkage issue. For this minor service and checking the shift issue (they said they couldn't find anything) they replaced all the fluids, sparkplug, filters, etc. They are claiming that is minor service, and billed me $600 ($480 for the minor service and $120 for checking the shift issue-and not seeing the problem). They said Honda specifies all those things for a minor service, but I think they are lying.
I would love any input on this before I take negative steps with them (BBB, credit card company, Google reviews, Yelp, etc.).
Your thoughts?
Agreed with all. And how about that biscuit sized oil filter to filter engine and trans....🙄I do all my own service. I've changed the oil twice by the book and both times the oil looked brand new. In my opinion, the service schedule is designed to benefit the dealerships. I was taught at Motorcycle Mechanics Institute in Phoenix, AZ (1999/2000 Motorcycle Tech 3 / Late Model Harley- Davidson) that motor oil is not even broke in until 2500 miles. The linkage is not that hard to adjust. There are a number of videos on the internet on how to do it along with just about everything else that needs to be done. I highly recommend a factory service manual for do it yourselfers. It is also my opinion that it is not necessary to check the valves as often as the company says to. Good luck, men.
Letting in run for several min and mine shifts ranges perfect, sometimes when its cold its a little stiff.Hi,
Your thoughts?
And not being an external spin on....😡
I agree on the valve schedule I've checked them several times and found them in spec. I didn't check them with the last service because its a pain in the ass. I'll do the valves and air filter before takeover with the next round of maintenance.I do all my own service. I've changed the oil twice by the book and both times the oil looked brand new. In my opinion, the service schedule is designed to benefit the dealerships. I was taught at Motorcycle Mechanics Institute in Phoenix, AZ (1999/2000 Motorcycle Tech 3 / Late Model Harley- Davidson) that motor oil is not even broke in until 2500 miles. The linkage is not that hard to adjust. There are a number of videos on the internet on how to do it along with just about everything else that needs to be done. I highly recommend a factory service manual for do it yourselfers. It is also my opinion that it is not necessary to check the valves as often as the company says to. Good luck, men.
Yeah, the other UTV’s have them.....🙄I'm hoping the aftermarket will come up with adapters to convert to spin on.
