Another Trailer Thread
So, I’m wanting to buy or make or steal a 14’ double decker trailer and could use input from anyone that may have knowledge of these. I’m very limited on weight. Cargo is 4K and I need not be over 6K total....🤔 Probably has to be an aluminum base????
something like this???? Minus the front area for a third vehicle.
4EB24E83 30A9 4BA0 94EB AFBDDD8AE828
Reactions: TxDoc
WagginTail
WagginTail
1,580
5,853
SC
What's the benefit of going up instead of longer? Just curious
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
With only 6k of towing capacity it’s going to be tough...especially when a plain jane aluminum car trailer is going to run 2500 lbs minimum on its own. Add in a ~1900 lb UTV that leaves 1600 lbs for the other vehicle/items.
  • Wow
What???? A Big Tex 14’ dove tail car hauler in steel is just 1620# what’s the point of an aluminum trailer if they’re not lighter than steel trailers.....🤔
9C0B3EF8 6DAC 4EC8 94FF 166EB39FD630
Reactions: WagginTail
Maybe a car dolly with a deck is a better option?
I just sold my car dolly, a Prius does not like to be towed with any wheels on the ground, it jacks with the computers. After I unload it all sorts of warning lights are on, breaking and steering is difficult and messages to get to the dealer are flashing......😂
  • Haha
Reactions: Tramguage1
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
My 18’+2 aluminum is every bit of 2000 naked. But it’s a higher gvwr as well at 7500 lbs. Toss in the chain box, jack, ramps, spare and winch plus battery and your at 2500 before anything is on it.
That’s crazy light for a steel trailer. The cross members must be a mile apart and the whole trailer made out of 14 gauge angle.
Reactions: Prntckt
Lol, I don’t know, but Big Tex makes damn good trailers. I own four of them. Anyway, I only need 14’ hauling a 2300# Prius and an 1800# Talon....😉
No 14 gauge angle, good specs...
I’m seeing 14’ aluminum car haulers at 1050#-1250#
tdhanses
tdhanses
1,044
3,553
Kansas
My 6x12 single axle aluminum is 776lbs With a 3500lb axle, can’t see a second axle adding much weight. A steal 6x12 single axle trailer is usually around 1000lbs.
I have a custom hybrid utility/dump trailer from D&K built like a tank that is a 6x14 with tandem 5000lb axles and dual lift cylinders rated for 10k in lift that probably weighs around 3000lbs, a 2500lb aluminum trailer must be built out of 1/2” aluminum.
Reactions: Montecresto
HPnMORE4J
HPnMORE4J
1,033
6,056
NW Oregon
Klagie
Woodford
Brian James
Trailer4 Trailer5
I bet you could get a steel one that would fit your weight limit.
Prntckt
Prntckt
1,093
7,625
Altoona, WI
  1. Talon X4
Featherlite 3110 are about 10,000 gvw, 3182 are 7000 gvw.
E668377B 71AC 49E8 BE75 DBB8409A2F25
Prntckt
Prntckt
1,093
7,625
Altoona, WI
  1. Talon X4
I‘m shopping for a 20ft Featherlite currently. Stock is pretty tight in my area.
