P1000 any one with a p1000 with a reverse issues
Aksnowhawk
Aksnowhawk
Alaska
I just got mine back together is wasn't the reversed gears was the clutch dog portion they were rounded and wouldn't grab also found that annoying chatter sound that would go away if dropping a gear it was the connector between the sub and trans had come apart and was just barely hanging g in there
Sent from my SM-G920T1 using Tapatalk
Was yours not going into reverse? And skipping when it did.... if so that will save me alot of head ache... thanks for the update.
riverratcadillac
riverratcadillac
173
626
lafollette tn
Mine made a pop and would just chatter like it wouldn't engage far enough and trying to adjust it didn't help
Reactions: Aksnowhawk
Neohio
Neohio
Beast of the East
21,761
93,350
Painesville Ohio
Note to self... Any and every time my P-1K has any problems whatsoever, be sure to audio and video record them and then upload full documentation of said problem to hondasxs.com or else be accused of lying about machine's problem. Got it. Thanks.
@0860silverado
Short story, They were riding together at RRB when @riverratcadillac was having issues. Hence the ribbing being thrown at each other.
0860silverado
964
1,862
louisiana
@0860silverado
Ahh...I see now. Thanks!
0860silverado
964
1,862
louisiana
Did you get your injector harness fixed with a proper plug? Or still running the temp fix you did?
Still running the temp fix. The only concern I have is moisture/debris getting past the injector pins and into the injector electronics itself. Don't know how well sealed that is. I may unplug it, clean it up and slip a large heat shrink tube over the whole thing including the body of the injector (when I have time, which is never lol)
IMG 20180831 230342601
Screenshot 20180901 123100
IMG 20180831 220047978
Screenshot 20180901 123203
The first pic with the red and purple wires is for illustrative purposes only. Those would actually be the Honda red and green harness wires as shown in other pics.
0860silverado
964
1,862
louisiana
Still running the temp fix. The only concern I have is moisture/debris getting past the injector pins and into the injector electronics itself. Don't know how well sealed that is. I may unplug it, clean it up and slip a large heat shrink tube over the whole thing including the body of the injector (when I have time, which is never lol)View attachment 89638 View attachment 89639 View attachment 89640 View attachment 89641
The first pic with the red and purple wires is for illustrative purposes only. Those would actually the Honda red and green harness wires as shown in other pics.
On second thought, I guess I should've posted these pics on an "injector harness" thread. Sorry for the hi-jack guys.
0860silverado
964
1,862
louisiana
0860silverado
964
1,862
louisiana
Eltobgi
Eltobgi
4,599
15,187
North Dakota
@riverratcadillac did you just replace the low reverse shifter or also the shift forks? What about bearings?o_O
C04B3952 5BAD 4116 B1B6 14CC53F83BA7
riverratcadillac
riverratcadillac
173
626
lafollette tn
i replaced the number 2,4,7 on the final drive shaft schematic and gasket and did the shift fork also but wasnt bad just cheap insurance why it was apart
riverratcadillac
riverratcadillac
173
626
lafollette tn
bearing on mine were all fine and i believe this was all due to it not being adjusted properly from factory and barely catching
Reactions: Eltobgi
riverratcadillac
riverratcadillac
173
626
lafollette tn
I had a bunch of noise leave to when I put this back together this was apart and the springs inside were laying in bottom don't know part name believed to reduce shock between transmission and subtran but all chatter left while driveing8f0493eea18b53bb7f018737d616d51eCd600206572d7fe7e2cd9136f0cd9b5a
Reactions: Eltobgi and JTW
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
It's pretty important to come to a stop when shifting from H L R. If the gear is spinning when the dog engages it can chip/grind the edge of the dog. If it tries to jump out from being rounded over or too slow to shift while moving, it usually bends a fork or shaft. Your usually better off slamming it into gear instead of easing it in with a dog box type tranny.
You mean like this?
8F044160 7665 4D8C 8D78 7D0D2B34F0E3
Reactions: Eltobgi and Mudwing
Similar threads
