riverratcadillac
I've sobered up in the middle and done the same thingYou mean like this?
Sent from my SM-G920T1 using Tapatalk
Hears list of part numbers@riverratcadillac did you just replace the low reverse shifter or also the shift forks? What about bearings?
We’ve all been there!I guess thats one way of explaining what happened lol.
Be rude not to finish!I've sobered up in the middle and done the same thing
Not bad at all! Looks to be a cheap fix! Thanks
Hears list of part numbersView attachment 109697
Hey Riverrat, this sound familiar ?
yes mine did the same think there was a pop and then the edges were rounded off its a cheap fix only takes a few hours
just basic hand tools and a manual real simple front diff has to be unbolted to remove front drive shaft and the whole subtrans unbolts like a transfer case and honestly i believe mine was out of adjustment and just didnt know it everything lined up fine but teeth wernt engaged all the wayDo you know why it happens and what keeps it from happening again ? Do i need any special tools ?
that double ring is what holds the ball bearingsRiverrat, the 2 images below seam to show some of the "DOUBLE RING COILS" in different locations on the shaft ?
No ring between high shifter and final drive on the (3and 9) microfich, no ring between low reverse shifter and reverse drive gear in ( 7 and 4) microfich.
Maybe I'm just seeing things but they look different to me . ????
View attachment 117754 View attachment 117755
The reason this is happening is because reverse drive needs to sit higher(further up on the shaft). I am thinking of adding more washers before the reverse drive so that it full grabs the dog ears. Do not know if the case will fit if I do this.
Correct, extra washers to keep the reverse drive gear from falling deeper in the transmission. I did a mock-up without extra washers to be sure it would not interfere with some of the gears that are splind. No way of telling once the cover is on. At first I thought someone might have not installed a washer or had the wrong thickness on the first washer, but I believe that is the way they come from the factory. All I can say is that by only replacing the two reverse gears is that it will happen again. The shifting collar, where the shift forks ride, would also be able to correct the problem because it would set the gears further in making full contact. Which it does sit further in during initial assembly.
i may be thinking wrong but if you add shim to one side it gonna give less engagement on the other sideMy thinking is if I add there will need to subtract somewhere else . Thinking about taking the second 29x43x1 washer and stacking it on the first. Only gain .040" but that's better than nothing. Find out tomorrow morning .
Leaning towards leaving it in the factory set up.
