P1000 any one with a p1000 with a reverse issues
Aksnowhawk
Aksnowhawk
Alaska
So I have almost 5000 miles on my p1000 it has 4" portals 30" tires and have had very few issues until this weekend.... out of the blue it now skips and jumps out of reverse... checked all cables and engagements . looking for a exploded view of tranny.
Reactions: Neohio
Neohio
Neohio
Beast of the East
21,711
92,788
Painesville Ohio
Reactions: Aksnowhawk
hondabob
1,309
5,215
Prescott Valley, AZ
0860silverado
964
1,862
louisiana
If I'm backing up a steep hill, mine makes a loud "bang" sound upon throttle. I imagine it's the splines overrunning each other. Hasn't gotten any worse or better so I'm runnin it! (It has done this since new and hasn't gotten any worse)
Aksnowhawk
Aksnowhawk
Alaska
Thank you for the reply... but my 1000 will not even back in the garage.... it's bad
Thank you for the reply... but mine will not even back in the garage .... its bad
Firemedic530
Firemedic530
387
1,133
West Jefferson, Ohio
@riverratcadillac
He's at RRB this weekend with a handful of us. He's running with no reverse and plans on tearing it apart when he gets home. I'll tell him about this post and I'm sure he'll get involved with this conversation as soon as he can.
T
tbaker
371
652
NW. Georgia
I don't trust reverse in these things I went to the woods the other day and had to back up a little incline and it made me wonder if it was going to make it or break first and I am talking bout just trying to back up a couple of feet didn't make and noise just jumped i was afraid to try and push it to see what it would do
riverratcadillac
riverratcadillac
173
626
lafollette tn
Your not the only one with out reverse mine made a loud pop and nothing now it was on flat ground no shavings in oil im in process of tearing it down i believe it ia a shift fork and will confirm soon as i can
Sent from my SAMSUNG-SM-G920A using Tapatalk
riverratcadillac
riverratcadillac
173
626
lafollette tn
I just got mine back together is wasn't the reversed gears was the clutch dog portion they were rounded and wouldn't grab also found that annoying chatter sound that would go away if dropping a gear it was the connector between the sub and trans had come apart and was just barely hanging g in there
Sent from my SM-G920T1 using Tapatalk
Can you elaborate on that chapter sound and fix
riverratcadillac
riverratcadillac
173
626
lafollette tn
My machine just cruising had a chatter sound and if reed way up disappeared I had to do some work in sub trans when I removed it the adapter in between was in pieces the clip holding it together was broke no longer have that chatter sound might be worth taking a peek
0860silverado
964
1,862
louisiana
Pictures of the damage, or it didn't happen.
Note to self... Any and every time my P-1K has any problems whatsoever, be sure to audio and video record them and then upload full documentation of said problem to hondasxs.com or else be accused of lying about machine's problem. Got it. Thanks.
Similar threads
