P1000 Auto versus manual what’s the benefit?
Plumber101010
Plumber101010
597
584
Western NC (Hayesville)
One thing that still puzzles me is the option to have manual only mode. What exactly is the possible benefit when the paddle shifters override the shifting when in automatic mode? If I’m in auto and at anytime I can downshift or upshift, then that is the best of both worlds and I just don’t see anything I can do in manual mode that I cannot do in auto mode by using the paddle shifters to override. Can someone explain that?
Not that I use it for racing, but in sport mode, when you get on it maximum acceleration, it shifts at very high rpm’s. Or in other words if you were to say the advantages in manual mode, is you can maximize rpm or speed before shifting, I find that you can’t go any higher in manual then automatic does anyway, as going past the rpm’s in manual where it shifts automatically now, is reving too high and could possibly blow the engine!
265,332
In manual mode you can keep it in one gear for maintaining a certain speed, for tasks such as pulling a heavy trailer, a brush mower, seeding a food pot, etc. Sometimes in those applications its better to not have the machine shifting gears on you when you're normally at a threshold speed it would shift up and down repeatedly when not necessary.
Skjerv40
103
169
Minnesota
I agree. Manual comes in very handy pushing and pulling in low (pushing snow or pulling a drag as examples) while trying to stay at consistent speeds or rpm. I feel the machine is geared too low in low range auto and rev’s like a S.OB. Manual cleans it up a bit, but takes a little while to get the hang of. That is all I use manual for.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
In low auto it drove me crazy constantly shifting between 1st and 2nd on trails. So i started using manual. That was over 2yrs ago. In past 2yrs ive used auto maybe 4 or 5 times even on the street.
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
One thing I noticed this last week, is unlike high range, if you are in low auto, the paddles don’t work. Low manual is the only place you can choose your gear.
Wonder why?
Reactions: BWAF
Plumber101010
Plumber101010
597
584
Wonder why?
If I’m not mistaken I’ll check out today but I’m almost 100% positive it doesn’t matter if you’re in low or high the paddle shifters override.
And thanks everyone for your replies I guess I haven’t really done any of those activities so that would explain one reason for it. In my experience if I’m going a certain speed it doesn’t shift back-and-forth, but again I’m not really pulling anything either lol
Plumber101010
Plumber101010
597
584
Wonder why?
Yep!!! My paddle shifters override auto to manual if I’m in automatic mode, either high or low! Maybe you have a different year model?
Reactions: CumminsPusher
63,409
When climbing a steep or technical hill you always want manual for better control.
Keep it in 1st or 2nd. You control the shift points up to the rev limiter and eliminate the gear change power loss.
Used it a dozen times this weekend.
mjn
mjn
1,409
5,206
Interesting... your paddles worked in low range auto?
huh.. well.. there was a bit of alcohol involved last week, maybe THAT was the problem! :)
Now I'm gonna have to try it again.
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
I learned to appreachiate that technique this weekend as well.
nbomar
nbomar
4,416
17,854
Springdale, AR
I use manual a lot in LOW mode to control the shifting when trail riding. Like @Delton said it’s very “jumpy” searching for the right gear in auto. I just use manual and hold the gear I want. This also is very useful on big hills where it will try to shift up then immediately shift back down.
Exactly... if you haven’t figured out why manual is awesome... then you need to ride harder!
Cal
Cal
70
122
Minnesota
I use manual a lot for the same reason the others mentioned as well as trail riding. Depending on the mood I'm in and who's with me (wife, kids, etc.), I'll use manual on the trails. I don't like it if I'm approaching a hill or incline, or some other technical obstacle and right before I get there it tries to shift up. I tend to use the paddles a lot while in auto, but full manual is nice when you want that full control because I can see what's in front of me and the machine can't. Also, it's just fun.
O
OleRed
142
275
Mine lives in manual-- unless just hauling down the road but that doesn't happen too much
Reactions: Cal
