I have an 8 gang wired up to control a bunch of different accessories and its been working fine until todays ride. I noticed that after anywhere between 5-20 seconds, everything connected to the auxbeam that was powered on would turn off. sometimes hitting the center off/on button would power the accessories, other times it wouldn't. If i turned off the engine and turned it back on, the accessories would work again for 5-20 seconds before shutting off again. The auxbeam remained lit/powered the entire time (except when I turned off and removed key -- its wired to key-on power). I tried it with each accessory individually and it didn't matter what device it was, it would do the same thing. When they do turn on, I hear a click noise (relay i think?) One accessory is measuring battery voltage, and both batteries were within expected ranges (12-14v).
Any thoughts on what could be wrong and where to start the troubleshooting?
