Back up camera
906UP
906UP
15,035
142,848
da Yoop
I'm running a samsung Tab A for my trail maps and looking to hook up a Bluetooth back up camera on the tablet ...Anyone foing this and got any suggestions on which is the best camera ?
Not sure if it's best or not but I got a wifi cam from Amazon that connects to my tablet, its in all the time, more like a rear view mirror
Here's the one I got
HD WiFi Digital Wireless Backup... https://www.amazon.com/dp/B07SGD3M1B?tag=sxsweb24-20
bumperm
bumperm
1,929
6,828
Gardnerville, NV
I just installed a wired one, pretty easy, as I already had ignition switched power to the top/front roll bar for my tablet, phone charger and refrigerator freezer (okay, I lied about that last part).
$50 for camera and display. I did have to make a wedge to mount the camera, as the roof is sloped, and the camera wouldn't declinate down enough to see the jack I have mounted for a back bumper. I wanted to see up close to avoid puttin a wheel over a mountain trail switchback where you have to go forward/reverse multiple times to make the tight corner. Ended up being a clean install, comes on with key, but if not needed there's an easy to reach button on the display to turn it off.
20240804 17310720240811 14321220240811 143303
Stevo
Stevo
86
144
Illinois
I just installed upper soft doors on my pioneer 1000 so had to remove my seismic side view mirrors so bought a 40 dollar back up camera off of Amazon and temporarily installed it. I think it will work out fine and keep me from backing into things. 🤞
IMG 3699
IMG 3700
Doogle
Doogle
216
312
Surprise,Az Cincinnati,OH
I have a front and back camera mounted. The monitor is mounted right in front of my steering wheel. The 5" monitor has a button to switch from front to back. I have it always on. I think it's better with narrow field of vision. It's a little better than just a novelty. Backing up to drop-offs may not require getting out to check distance. And I can see if someone is behind me. My front camera needs a more narrow field of vision. It is good when going up a steep peak to be sure there isn't an immediate turn either direction.
Scoop
Scoop
5,422
21,327
  3. Talon R LV
I installed a cheap $25 wired cam for a backup camera on the Pioneer. It's powered through a rocker switch on the dash. Hit the switch, wait about 7-8 seconds, then tap the camera shortcut on my Agama screen launcher and it fires up the camera app. I have the tablet set to auto-connect to the SSID that the camera broadcasts, so it pretty much comes right up (no need to go into WiFi connections and manually connect). It gets the job done. Made a little custom bracket to mount the camera under the roof.
1742324013804
1742324028872
1742324044072
Hometeam
Hometeam
1,045
4,414
Normal, IL
I'm gonna get one for my wife. If there is one tree in the middle of 40 acres, she will somehow back in to it.:mad:
Thank the Good Lord that I am not the only one married to one!! Sheesh. My wife has all the cameras and won’t look at them as she is backing into something….oh and the beeping alarm is just the beat of the music to her also!!🤣😂🤣
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
3,264
22,359
Route 66 Oklahoma
She even got around to marking her territory on the front end, a couple of weeks ago. She was giving a fellow female senior citizen her first UTV (and probably her last) ride and hit a tree with the front end. Busted some of the plastic around the headlight. Apparently that is part of an assembly that is not cheap.
Front1
Front3
Front2
moonsase
moonsase
6
6
wisconsin
what ever camera you choose , Make sure to mount it where You can clean off easy during rides
Doogle
Doogle
216
312
I'm not sure which camera I have. But it has a visor over it that seems to keep it pretty clean. I also have a front camera that stays clean. Rarely need to clean them off. My suggestion for you is to get the narrowest field of vision you can, depending what you want to use it for. I want mine to give a clear picture of how close I am when backing up or when trying to peek over the top of a hill. Is there a sharp turn left or right? Is straight ahead over a cliff? If you have a huge monitor, wide angle will be okay.
Reactions: CID
283,080
North Woods
North Woods
47
180
Maine
  1. Talon X4 LV
@JACKAL This would be my ideal setup but I'm worried about the durability of the screen. I just talked to customer service and they confirmed only the cameras have IP ratings, not the screen. I was reading the Major General Build Thread and saw he may have had some issues when it rained. I have a windshield but no full enclosure, and I don't plan to get one.
How long have you been running it? Has it gotten wet, and if so are we talking soaking wet or just misted?
Reactions: -Bear-
283,080
Mine has not gotten wet, but no issues thus far. Wolfbox has a new model the 900 TriPro that also has a front bumper camera option that starts shipping April 30th. But it's 2x the cost of what I have.
North Woods
North Woods
47
180
Maine
  1. Talon X4 LV
@JACKAL Just curious which hardware kits you got. Looks like they offer a hard wire package, a Polarizing lens for the mirror camera, a nice looking bracket to mount the mirror, and anti-glare film for the mirror. All of the parts are reasonably priced. If you were doing it all over would you spring for the new G900 pro? The technical specs for the different cameras are Greek to me.
283,080
I got the Wolfbox G840S 12" 4K mirror dashcam w/ backup camera:
And the Hardwire Kit, tying it into Key-on power only as it has a security function that will (optionally) video monitor the vehicle 24/7 storing video of any movement near it. - This would of course drain the battery
Now with the newer model available April 30th 2025 WOLFBOX G900 TriPro Bumper Version ) I would probably go with this version with the front bumper camera as well. That way you wouldn't need a wheel spotter waving his arms like being attacked by murder hornets and yelling while your trying to concentrate on driving :D
I still might get this one and put the other in my Pioneer, can't decide.
North Woods
North Woods
47
180
Maine
  1. Talon X4 LV
If you didn't get the mount, what did you end up using to mount it?
Reactions: BrianN
