P1000 Backup Light/Bed Light switch options
Dron_jones
21
I recently purchased the backup LED light kit from the Honda SXS store, the install was easy and the lights work great. After using them for a bit, I thought it would be really nice to be able to manually turn them on as well for use not just when backing up.
I’m no wiring guru but I do understand the basics. Would there be a way I could tap into the existing light wiring and hook up to a rocker switch so that I can manually turn them on? The part that was giving me some concerns is what happens if I had the lights turned on manually and also put the vehicle in reverse would I need some sort of diode to prevent any damage. Any help would be greatly appreciated!
Reactions: TxDoc
TxDoc
TxDoc
1,725
6,035
TEXAS 🇨🇱
photos.app.goo.gl
My cabin lights and bed lights are LED rock lights . Small, bright and tiny current draw. See what others are doing. Good luck
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
Club store has a 3 way switch just for that.
Reactions: TxDoc and TripleB
PioDawg
PioDawg
10
27
The store will definetly get in your pockets. Nice user friendly essentials.
Reactions: TxDoc
Lady01
Lady01
192
488
Midland Michigan
THis is how I wired mine, through a relay... also include a back up camera (using the reverse trigger)View attachment 233060
Honda Pioneer Reverse Flood Lights Camera Monitor DICE MODS
Reactions: TripleB and TxDoc
Riceman-Ducker
9
34
Central Illinois
I used a simple 3 way toggle switch mounted above my left shoulder on the roll bar structure support. Since it's a positive ground you don't need to run any wires from the battery. In one position the lights come on when put in reverse, in another they are on whenever the unit has "keyed power" and in the last position they do not come on at all if you choose.
Very simple to do , I think I got 5 of those toggle switches for $10 on amazon or ebay.
PioneerBackUp
Reactions: TripleB
Lady01
Lady01
192
488
Midland Michigan
Nice... simple.
3DTractoring
ME
Does the dual backup light kit that is listed for the 700 also fot the 1000? Thanks
