Backup light
Bachej
Bachej
Montana
You guys have all the answers so can someone tell me if you can mount the single backup light from store and also have soft rear panel? It shows mounting high but doesn't the panel zip around that bar? I am in process of gathering all the goods for dual battery and would like to know if this works before buying the light and harness from store...thanks
Reactions: TripleB and TxDoc
7,177
27,565
I believe the soft panels wrap around the upper roll bar and Velcro back to itself. I think you could cut a couple openings in the material and allow the light bar mountings to be outside the panel with the clamps being inside.
7,177
27,565
Backup2 2000x LIThink you could attach the clap, install the rear panel and just have t2 small slots in the material so these 2 mounting tabs are accessible from outside too mount the light.
Bachej
Bachej
Montana
Guess I'll give it a whirl...thanks
Jacks
Jacks
320
1,527
South Dakota
I have that exact setup and mounted the light dead center on upper roll bar. The soft Honda panel will velcro around it with out modifications..
Reactions: TripleB and Bachej
