While I agree the wireless remote "on/off" switch is advisable to prevent RFI (radio frequency interference), I disagree with using key-on enable for the winch (though that option is often put forth here). I think it better to retain the ability to use the winch with key-off - all systems shut down except the winch and it's wireless receiver (if equipped). This is so because there may be times, for whatever reason, the motor can't be run during the winching. If this be the case, then needing to have key-on to winch is simply wasting battery power for un needed electronic sub-systems while subjecting them to low voltage.Winch dash switches should be hooked to key on power.
So if that is all you use, you should be ok.
If you use a wireless remote, sometimes stray voltage/signals will operate the winch.
I will be adding an off switch to the winch remote control.
Have a good day
Yup! And in the case of a wireless winch remote, the power to the wireless receiver is switched as a fail safe to prevent radio frequency interference from inadvertently turning on the winch with potential damage.Never thought about this before, but I'm going look into putting in an on-off switch. I am planning on having the switch disconnect the low voltage to the relay that powers the winch, not the 12V line to the relay. This requires a much lower current rated switch. Is this how it is normally done?
@Smitty335 is your battery disconnected?Hey @HondaTech, I hijacked a thread a few days ago about an oil smell on my P1. Took off enough plastics to see what I needed to see and smell and let it run for 20 minutes and after all that I believe I have found the source of the smell, I believe the o-ring on the oil filler is compressed and not sealing the crank case again, replaced the first one with a Honda o-ring and it quit for a while, then came back. Time for a new source for o-rings. I tell my guys not to overlook the obvious and what do I do?
Yea I think so@Smitty335 is your battery disconnected?
My ground was loose, emitting terrible odors that smelled like oil burning when running?@Smitty335 is your battery disconnected?
Unless you are trying to stop the constant drain on the battery (even when the machine is switched off) from the wireless winch receiver.If installing a switch interrupt for the winch control, then there'd be no need to install a separate interrupt for the wireless winch receiver.
I did the same. My winch came installed, with my '21 SE, with only a wired remote, the wire being only long enough to allow you to get to the front of the vehicle. Also the winch clutch was buried behind some plastic skirting - which I promptly cut away so I could get to it without hanging from the roof by my toes - - or something.I put a switch on my wireless only. This way I can still use the dash switch if needed without the key on.
