P1000 Beefing up A-arm mounts
Damn it! Here!
680b9e09948355ab8083145c08dcca11
These are McMaster part numbers
Rambo
Rambo
339
822
Southern Indiana
Got a question for you welders out there. I gave it a Google to see if it was ok to weld chrome-moly to mild steel using mig and got mixed answers. (of course)
Tig seemed to be the best, but mig was okayed depending on the application.
I'm just looking to put in chrome-moly weld washers to my upper A-arm mounts.
Snuff I know you did this, you mind to chime in?
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
It's fine to do with a mig.
Rambo
Rambo
339
822
Southern Indiana
Got everything put back together. I put a new bushing kit in from SATV. The only sign of wear I found comparing the old pivot tube to the new one in the kit, was length. The old pivot tube was worn down. So this was probably the reason the bolt worked it's way loose which resulted in the egg shaped mounting holes again....
The chrome moly weld washers are a nice addition, they really added a lot more thickness verses the OEM frame mounts.
We'll see if this was a proper fix after a few trips out....
Rambo
Rambo
339
822
Southern Indiana
Rock Ready UTV. If you order any note the are sold individually, from there pic it looks like they come in a set. They were a perfect fit for the m10 bolt.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Did you notice any hardness difference in the bushing material old vs new?
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Ragnar406
Ragnar406
The Great Bald One
4,450
17,037
Bella Vista, AR
@Rambo do you run a lift?
Ragnar406
Ragnar406
The Great Bald One
4,450
17,037
Bella Vista, AR
Yes I have SATVs 3" lift.
Thanks , I know you had the holes for your upper A arms get bigger and I know Snuff and ohanacreek were not running lifts when they had it happen. So far both @GlockMeister and myself have not had that issue but both got our A Arms after they went to UMHW bushings. Since we both just removed our lift is crossed my mind that maybe the lift was preventing our from happening .... yea crazy logic but since you had a lift we can rule that out
Rambo
Rambo
339
822
Southern Indiana
I think in my case, the bolts just worked their way loose and I didn't catch it until the damage was done....
Don't think the lift played a role but the heavy ass tires I had didn't help matters.
All I know is my buddy has the same setup as mine, has never ran anything bigger than a 28" tire and hasn't had this problem.
