P1000 Beefing up A-arm mounts
Rambo
Rambo
339
822
Southern Indiana
Guys I know this has been covered in different peoples build threads, but I'm having a hard time finding and remembering who all has done this. I'm looking for different options and material used to beef up the front upper A-arm mounts. I recently had this done. The shop that did it welded 1/8 inch heavy grade washers to fix the problem. I had one side work it's way loose again and egg shaped the new washer. Not sure where my problem lies...... I had the nuts tight and even double nutted. I don't want to keep going through this! If anyone can post material used or links It would be greatly appreciated. This go round I will use red lock tight!!!!
Neohio
Neohio
Beast of the East
17,729
85,464
Painesville Ohio
Do you have pics of their repair?
I have some washers being machined right now to hopefully weld in and address this issue.
Is this only a problem with those people running super ATV arms? I have not had this problem with CATVOS arms but I did add gussets to the mounting locations and double the thickness of the mounting surface instead of using a washer.
5bf01eef03d03cf6c91280a995e3c0ae
1b2dd17ec7b9f554115b26bb79d96391
This bracket ties the front upper mount with the bumper mount. And also has an extra flange coming off the bottom to weld to the tube.
Fcfad4a60353d61000e370b43275b0c0
001acdc137846e8643ea3022a4b83e8c
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
I plated mine with chromoly and upgraded to 12.9 bolts and lock nuts. Wore the holes out again (1 ride) and machined washers to capture the heads of the bolts and welded in. Trashed the bushings after doing that (1 ride). So next I'm cutting the A arms and putting in heims and tabs for separate bolts like the bottom a arms. Red locktight and new locknuts and still came loose. The new UHMW SATV bushings may help as they should give a little more but I have not tried those.
Resized 20180909 133213
Resized 20180909 133239
Rambo
Rambo
339
822
Southern Indiana
That's a good question. From what I recall I've only seen this on SATV arms. Thanks for posting your fix!
Rambo
Rambo
339
822
Southern Indiana
Well hell after what you've done and still having issues that's more than discouraging. I know you're tire/wheel setup is heavier than mine but still....
I know I have the old style bushings, so I'm going to reach out to SATV and explain what's going on and see what there response is.
The guy that fixed mine I would think is pretty knowledgeable, he builds/repairs race sxs cages. He was surprised to hear about this issue.
I'll report back.......
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
I might still try the new bushings first. I already have heims and bungs and know that will fix it permanently but I will probably rip the whole frame off if I do haha.
BigOL3
BigOL3
2,994
8,920
Sounds like those A arms are causing me problems than I would care about dealing with.
Kinda screwed that sentence up ....... lol. I meant to say, sounds like those A arms would be causing me problems that I would not want to deal with.
Reactions: Rambo and JTW
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
We do ride pretty rough sometimes lol. Jumping, hitting basketball size rocks at 30, etc...
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
So is it only the upper mounts with this issue? I know Super ATV has a lower mount support/frame stiffener.
The uppers can elongate the holes with the satv arms. Both upper and lower fronts can be ripped off the frame. I braced for both before i had a problem. The bolt hole problem might be a lot better with the new bushings as the stock arm rubber bushings do not have a problem. Mine looked to be delrin and are hard bushings.
Reactions: Rambo
Rambo
Rambo
339
822
Southern Indiana
I've only had and seen issues on the upper mounts. I like my 30s but at this point wish I would have went 28s with stock arms. When I first had this problem I had a much heavier tire. Thought this was my main problem. Before I had it fixed I dropped down to a much lighter setup. Almost 13 lbs. lighter....
Well, the mother f***er SHOULD be able to handle it! I’m getting tired of all the little bulls*** stuff.. no, don’t “over” build your sxs Honda just do the bare minimum so everybody has to spend time and money fixing s*** that should have been right to begin with. While the “product improvements” are great and all... how about the 50 other little things we’ve all done to make them more trail worthy.
DDDonkey
Interesting, as right now I was leaning toward the Super ATV a-arm over the C-fab, but I may need to think a little more on this.
Reactions: ohanacreek
