Best recovery kits?
nbomar
nbomar
4,416
17,854
Springdale, AR
Ok I had a decent recovery kit with 2 small straps, 2 d rings and gloves in it and it’s disappeared. Recommendations on a good replacement? I thought about getting a winch rope extension as well since I have the narrow spool winch. Amazon and eBay links appreciated!
Reactions: sharp
7,143
27,170
Following!
Thinking this would be an awesome give a way at the 2018 Takeover
sharp
sharp
3,757
14,955
Tennessee
I think @Delton came across a pre packaged recovery kit at tractor supply.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
May just be my horrible memory but I honestly don't remember this lol. I'm sure tsc does have one though. I just have a tow strap and snatch block. I probably need to be more prepared than that though.
Reactions: sharp
Snatch Block
https://www.amazon.com/dp/B0027URE9G?tag=sxsweb24-20
Tree Saver Winch Strap https://www.amazon.com/dp/B00Z8R7T3Q/?tag=sxsweb24-20
Roll Bar Storage Bag https://www.amazon.com/dp/B01BLSTCMQ?tag=sxsweb24-20
Grey Soft Shackle https://www.amazon.com/dp/B07312V3Y5?tag=sxsweb24-20
3/4" D-rings https://www.amazon.com/dp/B01MZ0DKQK?tag=sxsweb24-20
AmSteel Blue 50' 1/4 Extension Recovery Winch Rope https://www.amazon.com/dp/B007TAXKY2/?tag=sxsweb24-20
(Note you can’t double line pull to this single line extension, you need to double it too or loop it through the block as a true extension.)
Black Tri-Fold Shovel https://www.amazon.com/dp/B004K299JW/?tag=sxsweb24-20
Deleted member 3748
Not a bad idea, Depends on the dirt.
Right. I use them in sandy lake bottoms all the time and they get a little tough to turn when you get down a few feet. I don't think it will be easy to turn these in dry, packed earth.
I have a little kit from TSC Dad found on sale.. I’ve added a few things to it but you all have pretty much covered it
Reactions: 13_xxc and sharp
13,364
65,121
Doesn’t your chinook have a winch on it?
B6FC62EB A14D 4A76 9C99 7D93AAD99D0B
66,418
I just added a hi lifter jack to my collection today. Invaluable if your blackwater evo comes off a rim and you need to change a tire @Delton
We used an old rear axle shaft sharpened to a point removed the lug nuts and used the holes to insert a shackle. We would drive it in at an angle with a sledge and then pull it out with the rig after we got out.
I’ve also dug a hole crosswise deep enough and used a highlift jack as a land anchor.
