Best sub compact cordless impact for removing lugs?
Jmaxx1502
Jmaxx1502
115
151
Cocoa beach
  1. Talon X4
Looking for a compact impact driver for changing tires? But they seem to powerful for the torque needed to remove/install. Is there one that the torque is adjustable? I think the Honda recommended torque specs are 80lbs?
Reactions: rtn001 and J80
SP82
SP82
101
356
CA
The talon and pioneer 1000 Honda recommends 98lbs for torque.
I have a 1/2” medium duty dewalt impact. Overkill for the Honda but also works on my f250. (165lbs) I think on high (3 settings ) it’s rated at 300lb and more for take off. It’s not giant but it is big. I like the lower setting for installing. They also sell a 3/8” version a little smaller and less power. Use a 2amp battery and it’s pretty compact also.
PaulF
PaulF
1,462
4,814
My Ryobi 3 speed 1/2 drive is pretty compact and does a great job. #1 is about 40 lbs, #2 is just about perfect at around 80 lbs. and #3 is around 120 and breaks lose stubborn lug nuts.
Honda Manuals for the Talon say 80 lbf-ft.
Owner's Manual...
1625719916597
Service Manual...
1625720044150
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
If you're already invested in a particular tool/battery combo, I'd go with that. I already had a few 20v DeWalt cordless tools so it was a no brainer for me to buy a 3/8" drive DeWalt bare tool impact wrench. The torque isn't adjustable but you can tease the trigger. For tightening I give it a few ugga duggas then follow up with a torque wrench. The specs are similar between the 3/8" wrenches so they should all do the job with ease.
colin215213
Where did you come up with the 98 ft lbs of torque? My Pioneer requires 80 ft lbs.
Hometeam
Hometeam
980
4,039
Normal, IL
I use the Milwaukee 3/8 M12 compact stubby and it does great! It has 3 settings on it. It's really small but has lots of power. It works great on trail repairs and in the shop. I have their mini aircompressor with M12 setup also. Those go with me everywhere from work to trails with me!
BigOL3
BigOL3
2,994
8,920
I have the 3/8 M18 Fuel with 4 torque setting, a little bigger, but still small enough.
60,375
I 2nd the 3/8" M12 Fuel stubby. I bought a cheap Pelican style case from Harbor Freight that I keep it in with an extra battery and the sockets needed for the Pioneer.
60,375
I'm going to guess that the 1000 is like the 700 in that the aluminum wheels are 80 ft lbs, while the steel wheels go to 98 ft lbs.
I prefer the 2 or 3 ugga dugga regardless of wheel. Haven't lost one yet! We should ask @Frogtown what he uses to put his wheels on since he literally had one fall off at TO 🤣. Probably the funniest thing I've ever seen on the trail.
1625755366228
Hometeam
Hometeam
980
4,039
Normal, IL
I have the 3/8 M18 Fire with 4 torque setting, a little bigger, but still small enough.
Great....now everybody here knows you have a bigger tool that you play with than my tool is....has my wife been talking to you?? Because she promised me that sized didn't matter and mine was "ok"!! Sheesh I can't even hide on the internet!! 🤓 🤣 🤣 🤣🤣
SP82
SP82
101
356
CA
See post 15. Manual doesn’t give options just says 98lbs.
TripleB
TripleB
15,241
136,125
Caryville, Tennessee
[/QUOTE]
That manual contains a contradiction/bad conversion/misprint.
108 n-m = 11 kgf-m or 80 ft-lb. Not 13.6 kgf-m or 98 ft-lb.
I've got a Pioneer manual that's missing like 4 or 5 pages. Not ripped out, just not there. Drove me nuts one day when I was looking for something and couldn't find it. After about 3 times back and forth I figured out the page I needed was missing lol
PaulF
PaulF
1,462
4,814
Yup, it is a misprint. For reference, same "Maintenance" page/area from a current Talon Service Manual with the correct conversion...
1625781746165
BigOL3
BigOL3
2,994
8,920
LOL ...... OK is, well ok ...... but BIGGER is better🤣🤣
