P500 Bigtee’s P520 Build
The Green Goat
The Green Goat
1,795
12,794
I’m hoping this will leave me room for power steering later on, I kept over toward the passenger side as far as I could.
Man, you move quick with the mods!
You'll be fine with power steering with your battery where it is.
Bigtee
Bigtee
556
1,213
Grayson, KY
I got a little bit of electrical work done today. Isolator installed, aux battery is hooked up and both bus bars hooked up. I got My switch panel installed but none of the wiring is hooked up. I will clean it up some once all the wiring is completed.
9B87DBF4 56F7 459E B945 B813FAA1EDC0
B880B3DB 5A2F 4C0F B558 C50A024E3B13
rustyneversleeps
rustyneversleeps
381
1,833
Montana
@Bigtee Did you ever get the seatbelt delete to work? Were you using this one?
Bigtee
Bigtee
556
1,213
Grayson, KY
I have the correct one now, the one that I had was for a P1000 or P700. Next time I have the seat out I will install it. I'm sure it will work correct now. For now I have one of these,
1621272607387
Bigtee
Bigtee
556
1,213
Grayson, KY
Also, if you are mounting a SuperWinch on the new StrongMade winch bumper, you’ll need longer bolts than what are supplied with the winch. Here’s what it took.
Correction, these are not long enough either. I have some 35MM and 40MM lenghts coming tomorrow. Maybe I will get the winch lined out finally.
