P500 Break Pedal Mod.
Glazer
Glazer
24
78
I'm thinking of removing my break pedal to cut and re-weld it so I will have more foot room.
I have long legs and big feet and the brake pedal is just to close for me.
I did some checking and the pedal only travels around 2" when fully compressed so there is more than enough room to make the change.
I'm thinking of just cutting and welding the pedal so it comes straight down, eliminate the forward bend,
Any ideals or comments.
20190228 123639
Reactions: trigger
Chooglin
Any ideals or comments. View attachment 111153
I think that's a great idea if you use your left foot for braking but not so great if you use your right foot for both gas and brake!!!
Reactions: Mudwing
Glazer
Glazer
24
78
I do use my right foot for both (brake/gas) but for myself, it is just to close to be easy to use like the gas pedal.
Reactions: Chooglin
NTCPrezJB
NTCPrezJB
President of #NTC
105,979
943,588
Canton, OH
I can't really tell from the photo, but if there are two bolts attaching the pedal you could possibly...
loosen both bolts
pull the top one
pivot the pedal forward
fab an extension plate to cover the gap between the old location of the top bolt and the new location of the top of the pedal
Insert the old bolt in one end and a new bolt in the other end.
It would be simple to undo should a future need arise and only cost you a bolt and a piece of scrap metal.
Just throwing out an idea. You would have to actually check to see if it is a viable option.
NitroxDiver
NitroxDiver
488
918
Concord NC
I wouldn’t be afraid to cut it and weld it back where I needed it and as far as the brake pedal goes I would move it too if I needed. If you have the skills to cut and weld it you could always add a pice back in if you don’t like it.
Glazer
Glazer
24
78
All done but have to have it powder coated.
First Picture - The stock brake pedal.
Second Picture - How I cut it and added a piece of 1/4" steel
Third Picture - Back view of the cut brake pedal after I welded it
Forth Picture - Side view of the cut brake pedal after welded
I will post a picture installed after I have it powder coated.
It came off the P5 very easy by pulling a couple cotter pins and springs.
The overall stock length was 9 1/2", I made mine a little shorter 9".
Brake pedal  1 Brake pedal 2 Brake pedal 3 Brake pedal 4
NTCPrezJB
NTCPrezJB
President of #NTC
105,979
943,588
Canton, OH
I like it.
Reactions: trigger
Chooglin
Honestly looks like they are far more even now. Should be better to pivot from the go pedal to the stop pedal without lifting the heel off the floor. I like it!
I agree , unless it's just the way the pic was taken. @Glazer are both peddles even now ?............I may have to do this mod. My biggest complaint on the p500 , is the lack of left leg room!
luckymike
luckymike
144
322
michigan
Great idea.let us know your opinion after few hours on the trails
Glazer
Glazer
24
78
Thank you,
I'm waiting for the weather to warm up a little so I can get my break in miles done and do my oil change. I only have 17 miles on it but I knew I didn't like the location of the break pedal.
Reactions: Chooglin
